Question about Canon PowerShot A85 Digital Camera
Canon PowerShot A85
My camera will power up on display mode and I can view pictures. When I try to power up the camera in shoot mode to take pictures the display say's "Change Batteries". I have tried many new batteries with the same result. This happened in a very high humidity area of Mexico.
    Novelist:
  • 103 Answers
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Canon PowerShot A85 - battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Posted on Nov 11, 2008
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
Scrambled image in shooting mode-Canon A85
It is problem of bad CCD Imager in your Canon A85 camera and ccd imager will be replaced to get correct picture in live view/ shooting mode.
Canon will repair your camera free of cost. Click Canon CCD Imager Advisory for details.
Thanks.
Sep 08, 2009 | Canon PowerShot A85 Digital Camera
Has horizontal lines and glare on the screen
I hope camera still able to show saved pictures correctly in playback mode and gives horizontal lines and glare only in camera mode, in live view.
If it is true then your Canon A85 camera got bad ccd imager problem.
Canon will fix it free of cost, click Canon CCD Imager Advisory for details.
Thanks.
Aug 13, 2009 | Canon PowerShot A85 Digital Camera
In shoot mode, display does not show picture. I can view old pictures in 'view mode'
If the ccd chip is damaged canon will change it for free bcoz it´s a canon fault with the defect ccd sensor
Mar 09, 2009 | Canon PowerShot A95 Digital Camera
No picture in lcd when camera is in camera mode
If it is Canon A85 camera then it has known problem of CCD Imager and this part will be replaced.
Canon will repair free of cost A85 in CCD Imager problem as per announced scheme.
Please click Canon CCD Image Sensor Advisory for details.
Feb 06, 2009 | Canon PowerShot A85 Digital Camera
PowerShot A85 Problem CCD sensors???
The CCD is faulty ... it is a faulty designed CCD ... Canon had recalled the product for a certain period just check if it is still on and get it replaced ..... or if you need a quick fix ...get the CCD replaced by your local repair man
Oct 12, 2008 | Canon PowerShot A85 Digital Camera
Powershot A85 bought Jan 05 LCD display works in playback mode but is blank in shooting mode. Camera does not take photos.
Your Canon A85 has problem of bad CCD Imager Sensor and this part will be replace to view live picture.
Canon has scheme to repair free of cost such problem in A85 model. Please check details to obtain free of cost repair at Canon CCD Advisory.
Thank you.
Oct 03, 2008 | Canon Cameras
A85 LCD stays off in all modes except "stitch"
Hi Toonz
I have exactly the same problem as Shimoni and Antonio with my 4 years old A85.
But sorry, its not a problem of the CCD, cause we all get a clear actual picture on the LCD but just in stitch mode! In any other shooting or playback mode the LCD is dark. So the sensor must be working well and Canon Germany doesnt repair for free. Our failure is different and we have to pay much more than the camera is worth ;-((
Dieter, Munich
Aug 28, 2008 | Canon PowerShot A85 Digital Camera
S500 Kept displaying pictures in shooting mode
Navigate the the rotating knob to manual or auto mode then shoot it then ok.
Dec 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Inverted image problem
Has this just happened or has it always been like this? There appears to be a a fault in the main board and only replacement will cure- So may be if the camera is more than a year or so old- time for a new one. Meanwhile do speak to the Canon Tech Support on the Web site. And whilst the matter is still not resolved ,shoot holding the camera upside down- seriously - tell me what happens.
May 19, 2007 | Canon PowerShot A85 Digital Camera
Canon PowerShot A85 Digital Camera Logo
419 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
