Question about Dynabrade Tools & Hardware - Others
Can i use my dynabrade sander to car polishar
I want to use this prouduct to car polisher can i use this for that?
  • 2,176 Answers
I would not recommend it for that purpose. A polisher has a much SLOWER RPM than a sander and you would probably cause paint damage from burning, secondly the polishing pad might not be rated for this higher RPM.
Posted on Mar 04, 2012
Why the oil will come out from the sander? how many oil drop must regulate the regulator
Oil coming out of the sander indicates that too much oil is flowing into the the supply air. The rule of thumb for oiling an air motor is 1 drop of light machine oil per minute, per 10 cfm of air.
Jan 16, 2014 | Dynabrade Air Tools & Compressors
Hi can I use my Dewalt polisher and change to sandpapper if so what parts will i need for instance glue new flexable pad sticky 220 papper can you please elaberate a little what in going to need thanx ...
I'm not sure I understand your question, but I'll give it a go.
The DW421 is a sander already. If you want to change it to a polisher, you can buy polishing pads to go on it.
If you have a Dewalt polisher and want to convert to a sander, you can buy sanding disks to fit your polisher. They are installed on the spindle and I believe you can get a backing pad for it also.
Hope that helps
Mar 19, 2011 | Dewalt DW421 5'' orbital sander
A friend gave me a 210055 3/32 Sander. I would like to get a manual for it.
Hi vepa, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Dec 05, 2010 | Dynabrade 6" Dynorbital-Spirit Random...
I want oil for the 7" air angle sander polisher by Neiko
http://www0.shopping.com/xFS?KW=sander+machine+oil&CLT=SCH
May 15, 2010 | Sander 7" AIR ANGLE SANDER POLISHER ...
Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
I ned the internal vein parts.
One of the cool things about the Dynaorbital Spirit sanders is that, they were designed to be the lightest sanders out there (as opposed to the Dynaorbital supreme). This is nice as it keeps hand fatigue to a minimum. Another cool thing about the spirit, is that it was designed to be able to change out the entire drive motor all at once. The drive motor being the rotor with the vanes on it. These motors are available from dynabrade directly. replacing one vane only will tear the sander body up fast. I would recommend you get the replacement motor from them. They can be found here:http://www.dynabrade.com/dyn09/intro/selregmark/index.html
TIP: When replacing the motor, be very careful not to compress the sander body (i.e. bench vice).Dynabrade sells a rubber grip collar for this operation. then you just R and R (remove and replace) the motor and yer' good to go!!
May 12, 2009 | Dynabrade 59035 5 Non Vac Dynaorbital...
I have 5" Dynabrade Orbital sander that needs a new sanding pad and could probably use a going over at the same time. Who does this work? Cost
You can get new pads at the automotive paint stores in your area. They are not expensive. Most of these wholesalers have a service department that can r&r yours. Hope this helps you, Rick
Apr 21, 2009 | Dynabrade Air Tools & Compressors
AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Apr 14, 2009 | Air Tools & Compressors
Tools & Hardware - Others Logo
79 people viewed this question
Top Dynabrade Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Dynabrade Tool and Hardware - Other Expert? Answer questions, earn points and help others
