Question about Sony Cyber-Shot DSC-F707 Digital Camera
DSC-F707 Digital Camera Problem
I have a DSC0F707 camera, just bought a NEW battery from Ebay ( after market battery).....Changed it all night, next morning the light was still blinking, when turning the camera on , it stays on for 10 seconds, and cuts of with air message.( for info LITHIUM BATTERY only )
  • 41 Answers
I did the same thing. What I found out was that it's very important to charge a lithium battery completely on the first use. You probably took it off the charger too soon. If it's not completely charged on the first use it won't be able to hold any charge.
Sadly, I ended up having to buy another one and try again.
Sorry.
Posted on Oct 26, 2008
O flesh da minha camera sony dsc f707 nao esta funcionando gostaria de saber o problema sera que tem alguma configuracao
hi sony f707 and f717 have very common flash fpc(flexible printed circuit) torn due to flash defuse unit up/down many time. it just need replacement. Thanks and best regard!
May 24, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
My Sony digital still camera F707 works very quick self timer (cca.2 sec.) May I readjust for original 10 seconds? Thanx for help!
There is no setting to change self timer, default time is 10 seconds. However you can reset camera to restore default settings by pressing reset button located under battery compartment, try it as it might correct self timer problem.
Thanks.
Jan 05, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
I have a dsc-f707 and the camera claims no memory stick is in it. I replaced it with two memory sticks and still the same message. Plus, can Memory stick duo work in camera?
I only got one reply and it was a "spam ad" selling offers from different camera repair companies. I ended up calling a local camera repair place and basically was told that the camera is nonfixable. The cost to repair is most likely going to cost the same as buying a new 12M pixal camera. So, why fix it?
Sep 30, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC-F707 camera cuts off after 10 second , just bought a new battery.
I also bought an aftermarket battery for my F707 on Ebay and got the same "for info...." message.
I contacted the seller and they sent me a new one and it worked, don't see a way around it.
Oct 26, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony digital dsc-f707 startup goes to "no memory stick"
Could be that the contacts on the camera are oxidised. Try cleaning the contacts with isopropyl alcohol and see if this helps. If not, it could indicate a circuitry problem. In this case, you'd probably be better off buying a new cam altogether!
Sep 28, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Camera does not turn on.
I had a similar problem and it was a result of the battery not charging correctly. I bought the travel battery charger and an additional battery from amazon to see if maybe the battery was just old or just not charging. I figured out that the internal camera charging mechanism just wasn't working b/c the battery charged fine with the travel charger. I like the travel charger better and with two batteries I can charge one while the other is in use. I haven't had a problem since. When you buy the new battery you still have to charge it before it's first use. I hope this works for you as it did for me.
Jan 06, 2007 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC-F707 viewfinder black
This same thing happend to me awhile back. Camera seem to be dead for several weeks until one day I tried turning on and then off the night vision. The was the usual click inside the camera and all was well after that. I still use the camera.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory stick problem
I had this same problem and the procedure it the following : IF YOU WANT TO SEE YOUR PICTURES, DOWNLOAD "PhotoRescue" INSERT YOUR MEMORY STICK CARD IN YOUR CAMERA, RUN THE SETUP1 AND FORMAT IT. Good luck
Sony Cyber-Shot DSC-F707 Digital Camera Logo
143 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
