Question about Home Security
Learn button on genie model 404 location - Home Security
2 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: own late model 12hp Genie
It will be on the outer surface of the motor head, or under the light cover. It will be the only one you can press. Some older units have dip switches which look like a row of toggle switches. If so there will be no learn button. Thanks BB
Posted on Nov 06, 2010
Learn button on genie pro max garage opener is not working . How can I programm new remote?
if the learn button is truly bad you have two options either replace the circuit board or buy an external receiver. It was me a would replace the opener with a Chamberlain/Craftsman or Liftmaster belt drive opener. The new genies aren't worth a damn. I've replaced about a dozen that were a year or less old because of defects this year.
Nov 07, 2016 | Genie Pro Building Materials
How do I program a universal remote to see a genie model 404 opener?
I don't think that the codes for this opener are going to be available for the remote type you have. Contact Genie or go on eBay and buy a used one.
Oct 25, 2016 | Universal Televison & Video
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
Where is the learn button located?
It's located in different places depending on which manufacture and model you have. Liftmaster will be a square button about 1/2 Inch, will be colored red, blue, purple, green, or yellow. Genie will be a small round button usually located on the front of the opener (older models) under the light lens. Newer model genies are a series of buttons you have to press in a certain order. If you will be more specific and add more details you will get better answers and usually faster responses.
Mar 02, 2015 | Building Materials
Learn button for model GXL9500 where is the Learn Button located?
That is a Genie Opener and there are several "versions" of that. Take off the light globe that faces the door. Two screws at the top should allow it to fall and hang from the bottom attachment. Locate where the wires for the eye beams and the wall button are attached to the opener. The learn button should be right under those wires. Good luck!
Jan 19, 2015 | Building Materials
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
How to program ct 68a remote
Text from manual below. Pictures of manual attached.
TO"LEARN" A FIX CODE PROGRAM FROM ANOTHER UNIT:
1. Press and hold both buttons (1 & 2) on the SPR. The LED will flash three times. Keep holding {for about five
seconds) until the LED flashes again (twice), indicating that it's ready to duplicate your garage door opener's
code. Release both buttons (Fig. 1 ).
2. Place your existing garage door remote and the SPR unit within an inch of each other. Press and hold the
first button on the existing unit while pressing button 1 on the SPR unit. The LED will flash, indicating that it
is learning. Keep holding the buttons until the LED light goes out. At this point, the SPR unit has duplicated
the code (Fig. 2).
3. Follow Step 2 to duplicate another code.
4. Exit the learning mode after duplicating codes by pressing and holding both buttons on the SPR unit. The
LED will flash once to indicate that you have exited learning mode. Examine the unit to see if your codes
were duplicated completely.
TO EXAMINE CODES:
If the remote is programmed correctly, the LED stays lit while the button is pressed.
If code duplication has failed, the LED will flash when the button is pressed. Follow Step 1 again if duplication
has failed.
TO LEARN GENIE ROLLING CODES:
Genie rolling codes require special additional instructions to program. Once step 1 through step 4 of the Fixed Code
Instructions are completed, you must do the following:
A. Pra•ce the SPR on the top surface near the rear of the original Genie
Remote instead of setting the two units side by side during Step 2 of the
Fixed Code Instruction; shown as Fig. 3
B: Press the Learn Code Button on the Genie Unit. The LED on it will keep
flashing.
C: Press the program button on the SPR. The LED on the Genie Unit will stop
flashing and become a solid glow
D: Press the same button on the SPR for the second time- turning off the
LED light on Genie Unit and finish the Genie Code Duplication.
E: Follow the EXAMINE CODE section of the fixed code instruction to test code duplication.
F. Follow the above steps if you wish to duplicate another Genie Code on your SPR.
NOTE:
If the first time you only programmed one button on your SPR, and you would like to program the second button later
on, either with FIXED CODE or GENIE ROLLING CODE, you will have to REPEAT step one of the fixed code
instruction to enter the leaning mode; then follow the instruction listed previously. After duplication, you will have to
repeat step 4 of the fixed code instruction for exit learning mode as well. This is very important.
Nov 07, 2011 | Brookstone 538744 Remote Control
Need to change the PROGRAMMING. Need new code set-up. thank you.I have no manual.
  1. Gently press the Receiver Learn Code button on the power head receiver of your door operator. This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. **
  2. After pressing the Learn Code Button once, press your transmitter button three times for your system to grab the frequency and code it in. (Keep the transmitter you want tuned at least 2 feet away from the power head while tuning.)
  3. Press the transmitter button once more to test the system and start your door moving.
**To erase all Intellicode remotes and wireless keyless entry, hold down on the learn button until the indicator light stops blinking, then proceed to Step 2.
Jul 09, 2011 | Genie Company Genie Intellicode...
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
Own late model 12hp Genie screw drive garage door opener and want to know where to locate the Learn Code Button.
Oct 22, 2010 | Genie Company Genie 33944A Excelerator and...
Home Security Logo
287 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
