Question about Car Audio & Video
I have kenwood kac 921. it has bridged mode. but I do not how to connect wires for that mode please help.
  • 631 Answers
SOURCE: kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
SOURCE: WIRING MANUAL
tough ****
Posted on Mar 31, 2008
PWR_USR
  • 9 Answers
SOURCE: kenwood kac9152d bridge mono wiring diagram
only using one of the channels for audio and having the rest of the amp wired up as normal should work fine. for example just use the right channel and leave the left unwired.
Posted on Dec 28, 2008
  • 46 Answers
SOURCE: KAC-9104D output terminals
Mono is mono...it just looks neater and is a lil easier to hook up
Posted on Jan 14, 2009
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
How do I wire a 2 ohm speaker to Kenwood kac 921
Positive to the red terminal and the other to the white or black terminal.
Nov 01, 2016 | Kenwood Car Audio & Video
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
Just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
Hello bigmac208,
Yes, that would be the best connection for both the subs and the amp.
I'd wire the sub voice coils in series since the amp will not be stable at 2 ohms when the channels are bridged. The power will be somewhere between 100-200 watts RMS to each sub. While it's not pavement pounding, it should provide pretty good bass, especially if you tweak the crossover and boost settings for best bass response.
Hope this helps.
Aug 28, 2009 | Kenwood KAC-X501F Car Audio Amplifier
They are not wanting to play like they should
Hello again debrahood196,
Your KAC-5204 amp is only rated to put out 60 watts per channel and really cannot push very hard. If your subs are the KFC-W110S, they are 8ohm subs and you will get better power from the amp by using the bridged connections, positive (+) on the left channel and negative (-) on the right channel. Wire both positives and both negatives from both subs to the bridged connections and the output will be 150 watts into 4ohms. Giving each sub 75 watts should make them push a little harder.
May 17, 2009 | Kenwood Car Audio & Video
Hello laurogleal,
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Help
If it only does it when bridged, the ohm load may be too low.
Is it blowing the fuse on the amp or the one near the battery?
Jun 15, 2008 | Kenwood KAC-7252 Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
