Question about LG Heating & Cooling
LG 3PHASE DUCTED SR061 COMPRESSER - LG Heating & Cooling
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: tcl ducted 3phase system compressor runs 12mins
Check your room temp sensor is defective. Replace it.
Posted on Dec 26, 2010
IS IT EASY TO REPLACE CAPACITORS ON A LG OUTDOOR DUCTED AIRCONDITIONER.
Replace them with the exact one. and yes it is easy they plug in and there is a strap that holds them in place.
Oct 28, 2014 | LG Heating & Cooling
Is my Louis Vuitton real the serial number is SR061-9 how much is the pocketbook worth
Only as much as the next person is willing to pay for it.
Aug 02, 2014 | Watches
Hi I have lg ducted type air co works fine on cold air but when switched to hot air will not work outside compressor does not come on
Outside temperature too warm to allow heat to come on. It would rapidly overheat the compressor.
Jul 01, 2014 | LG Heating & Cooling
Need compresser for lg model nb g.r.m392ylq compresser nb nd52labm
Here is a tip that will help you with the onlinebuying...
How to Buy Appliance Parts Online
heatman101
Mar 15, 2011 | Refrigerators
I have a new LG ducted AC unit B62UWYUY81 and geeting error code CH 54 on the remote controller . Can you help to reset the system.
Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
Feb 11, 2011 | LG Heating & Cooling
LO error code LG ducted
In my lg ac it automatically shut downs and restarts and lo is written in stead of temp what is the problem and what should i do?
Nov 20, 2009 | LG Heating & Cooling
LG 3phase ducted CH02 fault (internal pipe thermistor error)- every day. When it comes up the air con shuts off, and takes a few hours to clear itself. Very annoying. I notice though it comes up less if i...
have u checked your low pressure and high pressure when compressor is on. Remember the compressor has a thermal protection switch if the compressor has too much freon the A.C will work for a while turn off, then turn then off and on. Are the air filters for the evaporator clean, is the blower fan blowing the correct way. How long ago did the evaporator coil got cleaned. With a properly cleaned filter and evaporator coil you can now check for pressures. Use your ammeter and check how much the compressor is pulling and compared it to the name plate. How much tons your A.C. If you give me how much tons and low and high readings I might help you diagnose the problem. Make sure the evaporator is clean blower blowing correct way condenser cleaned and condenser fan rotating the correct way
Jul 24, 2009 | Heating & Cooling
Air compresser relay 01 navigator
You will have to access it from under the vehicle and it is located right behind the right headlamp. The wire colors will be LB/PK,DB/YE,LG/RD,GY/RD.
Mar 22, 2009 | 1999 Lincoln Navigator
LG AC/compresser
check all air vents closely for accumulated carpet fibers, dust and gunk that may have accumulated and vacuum thoroughly.
Feb 16, 2008 | Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
