Question about Fisher and Paykel Washing Machines
I have just gone to replace motor controller on GW712 top loader washing machine but have found that the motor pump connections to be different. Old controller has 5 pin plug that does both, new controller has two seperate three pin plugs. Wires running into 5 pin plug in order (looking from back of machine) are blue, yellow, red, brown, white how do I adjust wiring to fix problem?
  • Fisher and P... Expert
  • 555 Answers
The new motor controller board has a plastic breakout bit on the pump socket witch will give you 5 wire motor/pump.
No mod needed to wires or plugs.
Posted on Dec 26, 2013
  • 351 Answers
SOURCE: hoover 710 top load washer
They sound
Posted on Mar 02, 2008
  • 150 Answers
SOURCE: Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Posted on May 08, 2008
  • 1462 Answers
SOURCE: washing machine
green and yellow is earth so wire the earth wire to this. brown is live in and blue is neutral in. brown/white is live out and blue/white is neutral out. usually a suppressor capacitor has a diagram printed on it
Posted on Oct 15, 2008
supernova278
  • 1932 Answers
SOURCE: I am replacing the replacing
It is red/Yellow/Blue
I have attached diagram for easy understanding
Thank You
Posted on Oct 09, 2010
  • 557 Answers
SOURCE: smelled a carbon/burn smell during a wash. went to
you just rounded third, bring it home baby
Posted on Oct 21, 2010
Testimonial: "Thanks! Please note I detached the red wire from the capacitor before stripping and connecting. capacitors can hold a charge a while."
Samsung top loader washer no power
sounds like a controller board psu error
perhaps a capacitor has burned some connections
i know top loaders use motor start capacitors and some live connections unify at the motor and then one goes too the controller board ... so some can burn can cause this but most often
some safety component fuses
in all machines everything has power supplied via the controller board unless the heater element has gone and blown a fuse then its a job for a tech .... or a good pal with the right knowlage
Mar 05, 2015 | Samsung Washing Machines
GW712 will not agitate or spin, 1st and 7th lights lit, beeping every second.
Your Error code is 130
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Apr 24, 2014 | Fisher and Paykel Washing Machines
Gw712
Fault code 130
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Action: 1. Check for corrosion on the edge connector of
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
the socket has two wipers. If the distance
different contacts, replace the rotor positional
sensor harness.)
Action: Check the Rotor Position Sensor with an R.P.S.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Feb 29, 2012 | Fisher Paykel EcoSmart GWL15
Detailed service manual for a fisher paykel gw712 washing machine
i'd say its either blocked pump or hose, faulty pump or motor controller, the latter 2 being a bit expensive, most people throw these away if the motor controller fails, cos its expensive!
Sep 17, 2010 | Washing Machines
Loud noise when draining
You need to tilt this machine back and remove the drain pump from under the machine and check for anything stuck in there eg a hair clip or coin etc. If there's nothing stuck in there you may need to repalce the drain pump. Cheers
May 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water flow into machine dribbling - Fisher and Paykel GW712 (AU)
The first thing that needs to be done is to disconnect the fill hoses from the back of the machine. Once disconnected, look at the inlet valve screens and check for blockage, if clear, open the water valves and check for water flow through hoses, if not clear, clean screens at fill valve, reconnect hoses & check for operation. If the problem remains, then the problem is with the machines fill valve & it would need to be replaced
Apr 30, 2009 | Washing Machines
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Best way to drain washer to check pump or hoses
broken lid switch usely the call what kind top loader is it
Feb 26, 2008 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Washing Machines Logo
78 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
