SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: Canon pixma MP600, error code 5010, what does it mean
There are a few things you can try:
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Testimonial: "Thenk you very much for your assistance, I will try your solutions. regds Robert"
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
SOURCE: Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
