Question about Briggs & Stratton Garden
Hi i have a B&S 650 190cc idiling is bad at low revs and pops out muffler please help
Poping through muffler
  • jonny Mar 05, 2012
    new spark plug new filter still the same.
  • Briggs & Str... Master
  • 2,239 Answers
Try a new spark plug and fresh fuel, clean/replace the air filter.
Posted on Feb 18, 2012
Trotle hesitation poping in mufler no power going up hills
Can't offer much help but popping in muffler would indicate unburned fuel is being pumped into exhaust manifold.
Jan 15, 2013 | Cars & Trucks
2004 1200 sportster when hot and at idle the motor pops when you rev it to take not all the time
Hi Jim, I think I would go through the carburator paying close attention to the slide and diaphram, also replace intake seals. Good luck.
May 22, 2012 | 2004 Harley Davidson XL 1200 C Sportster...
I have a 2003 heritage efi got gag and now it is poping through the intake a lower rpm when i rev it up it seems to go alright but pops when i try to take off
Hi Drbob6953, popping, coughing, spitting, or backfiring through the carburator or induction module can be caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck and have nice day.
Apr 11, 2011 | 2003 Harley Davidson FLSTC Heritage...
My 1998 Explorer on startup idiling to high, it occasionally revs up and down while idiling. Is there a trottle position sensor that controls the idiling rpm?
there is a tps located on the intake where the inlet tube for air intake connects, it would be on the left side of the throttle body. does the trk run rough on idle? up/down sputter sometimes stall? Is check engine light on? if no light,check all vacuum lines for cracks/splits loose fit. do this by spraying carb choke cleaner on connections motor rpms will change if leak is present. also spray around perimeter of intake housing where mates with lower intake if engine revs you have bad intake gasket.I Just replaced upper and lower intake on my 98 and shazaam, runs like it should. but do your checks first,unessasary fixes are costly and **** you off.
Jan 03, 2011 | 1998 Ford Explorer
Starts easily, but won't rev for 10 mintues. After warm, max speed is low / lacks power. New plug & gas filter
Check to see if the muffler is blocked.There is a screen (spark arrester) at muffler exhaust these get blocked. Usually 1 screw holding it in. Remove screen and replace or clean. I use bernzomatic torch to burn out these deposits.
Oct 01, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Dose the engine have a rev limiter fitted when road testing bike popping back through exhaust on over run / when taken to high rev holding back on road test
Most engines with cdi boxes have rev limiters. Popping or backfiring could also be caused by low back pressure (aftermarket muffler) and most commonly bad exhaust gaskets in the head.
Mar 20, 2010 | 1999 Honda VT 750 C2 Shadow
Stihl ms192t, idile increases when tilted down and decreses, then quits when tilted up, have cleaned & o/h carb, removed muffler & checked for cabon, cleaned fuel tank & filter? please help
The leaner the saw the better it runs until it seizes. I suspect you have a hole in a fuel line that gets exposed to air when tipped. I would replace my fuel lines. if the problem persists time to visit your friendly neighborhood Stihl dealer.
This may be of help:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
I hope this was helpful. If this is not the problem please post back with the fix. It helps me to improve.
Lou
Jan 19, 2010 | Garden
My Fuel Fuse Keeps poping
I'd try a 20 amp maybee even a 25
Sep 17, 2009 | 1999 Pontiac Sunfire
I have a Mcculloch Model Mac 3227 whipper snipper. I am wandering how to tune is so it does not over rev when on idil.
There should be a "HI" and a "LOW" setting. There should also be an adjustment for the idle speed. Each would have a screwdriver head on it . Look closely. You would adjust the idle setting, not either marked H or L...Lee
Sep 17, 2009 | Garden
Ideals ruff
Sounds like a sticking Idle speed control valve (motor). I see a lot of this
Jan 03, 2009 | 2002 Lexus RX 300
Garden Logo
104 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
