Question about InFocus IN78 DLP Projector
InFocus IN78 powerup issues
I replaced the lamp and in78 worked fire for about two days. then it wouldn't power up. i removed the lamp, and the square, glass lens on the front was cracked. so i replaced it with the lens from the old housing and reinstalled the lamp. now, when i plug it in, it starts to power up for about three or four seconds, and then shuts down again. unplugged the power cable, plugged it back in and got the same results. any clues?
  • 26 Answers
SOURCE: Infocus x1a projector shuts down after 30 seconds - dust problem ??
Most likely, if it is a thermal problem, your main cooling fan has quit or is stopping after a short period. The problem is, I've seen several of these do this, and in every case, it is not the fan that has failed, but the Controller Board. And that is a very expensive part.
Posted on Mar 12, 2008
Marrie
  • 563 Answers
SOURCE: Lamp automatically turns off
Hi there
Did you reset the lamp timer ?
Posted on Apr 02, 2008
Mark_Webber
  • 472 Answers
SOURCE: Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Posted on Apr 11, 2008
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Posted on Nov 05, 2009
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
I have an Infocus 24+. I just replaced the lamp. it worked fine for two days. Now it wont boot up and a red light (not sure what it is) flashes shortly after powering up.
it may have beeen another issue, not just the lamp. clean out the projector with canned air to get rid of dust, check the fans and colorwheel. if none of them spin, you have a power supply or main board issue. might be worth sending it in for repair. try www.avsolutionsny.com. they're an infocus service center and they're really good.
Jan 14, 2010 | InFocus Office Equipment & Supplies
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
Infocus lamp not firing
more then likely the ballast has gone bad and the lamp is not getting the right voltage to fire. Only other thing you can do is remove the lamp the turn the power on and check the voltage at the connector. This will not check the triggering voltage mine you only the lower operating voltage. But since you have replace the bulb with a known good one I'm betting on the ballast is bad.
Dec 08, 2008 | InFocus Replacement Lamp Projector Lamp...
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus 540 lamp didnt strike keep trying
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
LP580 not powering up
reset lamp hrs and flash new software.
Nov 06, 2007 | InFocus Office Equipment & Supplies
Projector Problems
Sounds like the fuse popped. t5a=5 amps 250v=250 volts So you will need a fast-acting 5 amp 250 volt fuse
Mar 14, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus IN78 DLP Projector Logo
59 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
