Doesn't burn completely
Doesnt burn complete disc.. a 4.1GB file should burn almost to the end of the disc, but what its doing is starts to burn in the center then stops less than half way
Try to burn your DVD in slow speed. and try to see whether the file which you are trying to burn is intact without any errors.
Posted on Feb 17, 2012
2 Suggested Answers
cpenzes
  • 1102 Answers
SOURCE: media center
uninstall media center and restart pc and then reinstall
let me know if this solved
Posted on Feb 13, 2009
EEB020B8D
It's possible you got a bad batch of discs or your drive might be going bad. Or maybe your burning software isn't very good.
Try burning the disks with Imgburn. It's FREE, works great, and you can get it here:
http://www.imgburn.com/
Jul 23, 2012 | HP Computers & Internet
Front panel on machine just reads ..disc not finalised.what does this mean please?
Are the discs ones that you created (burned), someone else burned, or commercial discs? The message of disc not finalized usually appears when you put a CD or DVD from one unit into anther without closing (finalizing) the disc. The finalization step doesn't matter if the disc is being moved between computers with compatible OS versions (for example: XP through Windows 7). However, any other device will need this procedure completed.
Take the disc back to the unit (computer or other burner) where the disc was burned. If the computer uses Windows, put the disc in the optical drive. Open My Computer (Computer) depending on the OS by double left-clicking on the icon on the desktop. Right click on the optical drive and select Close Session.
If you created the CD on another machine, check the details for that device.
Note: you should double-check that the format that you burned to disc is compatible with this CD player. Not all models support MP3 files. On my own older CD player, I had to burn WAV files without gaps in a Disc At Once format to get the discs to play without skips.
I hope this helps.
(if the discs were commercial discs or have been finalized, I would expect a different error. In that case, I'd suspect a tracking problem and a "No Disc" error.)
Jun 15, 2012 | Marantz Audio Players & Recorders
How to finalise dvd in real burner
1 Open the DVD creation software of your choice. Exact steps will vary based on the software you choose. Nero and Sonic are two popular choices.
2 Create a new DVD project or open an existing project. You will need a blank DVD or an un-finalized DVD with an existing project on it in your DVD burner.
  • 3 Add any files to your project. All programs have an "Add Files" and "Browse" button in order to add files. To remove any files, select the files in the list and press "Delete." Be sure your project is exactly like you want it before proceeding.
  • 4 Press "Burn" to burn you project or changes to DVD.
  • 5 Press "Finalize" or "Finalize Project" when prompted. There will be a prompt after the burn process has completed. If you don't see a prompt, look at the options menu that is to the left or top of the screen. Select "Finalize" or run your mouse over the toolbar buttons until you find the "Finalize" button. Select or press "Finalize" to finalize your DVD project. Select "Ok" or "Yes" to confirm.
  • 6 Eject your DVD and test it in a regular DVD player. A regular DVD player is one that doesn't burn DVDs and is more than likely a portable DVD player or one that is connected to your television.
  • BMW Brake Kits
  • Jun 07, 2012 | Sony BDP-S470 Blu-ray Disc Player
    Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
    Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
    The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
    Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
    If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
    If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
    I hope this helps.
    Mar 31, 2012 | Televison & Video
    'setup having problems to shut down auto run program' Sims 1!
    Try to clean your CD's thoroughly before installing it and "run it in administrator account"........
    Feb 10, 2012 | EA - Electronic Arts Sims: Complete...
    At the end of Trouble in the Sky, after I get the last batch of seagulls, the game locks up completely.
    Take out the disc and clean it. If that doesn't work your disc is messed up. I'm sorry.
    May 03, 2011 | LucasArts Entertainment Company Lego...
    Something simple probably, I figured it out before but now I'm just too frustrated to remember how I did it. Problem is..."Please make sure ISO9660 + UDF 1.02 file system is selected" WHERE...
    Make sure the checkbox besides the video files you want to convert and burn has been ticked. If there is none video been ticked, the program prompts when starting conversion or burning. When all the checkboxes are ticked, the video files added in will be converted and burned following the order of the file list.
    Sothink Movie DVD Maker supports burning movies to various discs like DVD+R, DVD+RW, DVD-R and DVD-RW, and it also supports burning movies to different target disc sizes like "DVD-5" and "DVD-9". Those target video settings are all set in General Settingsor Advanced Settings panel.
    Note: If you would not like to burn movies once the video files conversion is completed, please un-tick the checkbox "Check disc status before starting encoding" under dialog Options. Meanwhile, please make sure there is no disc in the CD-ROM.
    If there is no DVD writer in the PC, when the video conversion and DVD menu creation are completed, it pops up a dialog to prompt that a folder for the DVD structure has been created successfully. Just click button "OK" in the dialog to open the folder and burn all the files in that folder to disc using your burning tool.
    Please make sure ISO9660 + UDF 1.02 file system is selected while burning the disc.
    hope this helps
    Jan 20, 2011 | Computers & Internet
    I want to reset it
    Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
    Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
    Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
    Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
    Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
    Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
    Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
    If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
    http://www.vtechsquad.com/acer-support/
    Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
    How do you burn a cd on this notebook?
    1. Insert a writeable CD or DVD into your computer's CD or DVD recorder.
    2. In the dialog box that appears, click Burn files to data disc.
    3. In the Burn a Disc dialog box, type a name for this disc, and then click Next.
      It might take several minutes for the disc to be formatted in the default Live File System format. When the formatting is complete, an empty disc folder opens.
    4. Open the folder that contains the files you want to burn, and then drag the files into the empty disc folder.
      cdb4d559-8825-47a1-8175-79020965d91c.pngYou can copy files to the disc folder by dragging them to the disc icon or to an open disc folder As you drag files into the disc folder, they are copied automatically to the disc.
    But I recommend you to use any CD or DVD burning software like Nero, BurnAware etc. There are lots of free burning tools available on Internet too.
    Why I recommend third party software is because you can select burn speed plus minimum disc burning error.
    Feb 02, 2010 | Toshiba Qosmio F45-AV412 Notebook
    MadDog MD-16XDVD9 could not perform end of disc-at-once
    Have you tried checking your basics ?
    Firmware ?
    ASPI ?
    Disk Defrag ?
    IDE location ?
    Jumper settings ?
    What type of media are you using ?
    What programs are you using ?
    Exactly where are you and what are you doing when your error occurs.
    What are your PC's specs ?
    Do you have any Roxio products installed on your PC ?
    Please answer ALL of the above - if you don't know, say so, don't make something
    Oct 20, 2009 | Computers & Internet
    Computers & Internet Logo
    32 people viewed this question
    David Payne
    David Payne
