Question about JVC Televison & Video
There is a clock box in the bottom right corner of the screen, how do i remove it.
    President:
  • 2,712 Answers
That probably indicates that the Timer function has been set on the TV. Using the menu option through remote, navigate to timer and switch it off or change to 0.
Posted on Oct 26, 2008
WiFi authentication issues
Check the time on your computer's clock in the bottom right corner of the screen (on Windows). Is the clock and date correct? If they are not, then set them to the correct time and date. Hey presto, authentication problems on browser solved.
If your clock keeps needing to be reset every time you start up the machine, then your CMOS Battery is all used up inside the computer and must be replaced by a qualified professional.
Sep 23, 2017 | The Computers & Internet
Screen goes black unless it's on charge, even though it's fully charged
Right click on the battery icon in the taskbar (Normally located near the clock, bottom right corner of the screen).
In the sub-menu that pops up, select "Power Options".
Next to the power plan you are running, to the right of it, click on "Change plan settings".
Scroll down to and click on "Display" and you will see the computers setting options for both "On battery" and "Plugged in" with the screen turn off time in drop down boxes.
You need to select what time the screen turns off in when no user input is detected for that time. I usually select 5 mins for battery.
Hope this helps, and wishing you a Merry Christmas. ;)
Dec 15, 2013 | Computers & Internet
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
Sep 12, 2011 | Dell Dimension 4700 PC Desktop
How do i close window messenger so as i can install adobe flash player 10.2
find the picture icon for the messenger on the bottom right side of your screen near the clock area. Sometimes you will see a down pointing arrow instead. Click on this arrow to open the area and locate the picture of the windows messenger. right click with your mouse on the messenger and choose "exit" and this will close the program.
Mar 21, 2011 | Computers & Internet
What if in the bottom right corner of my screen there isn't a speaker, does that mean i have to install my headphones?
Go to your control panel window and open you Sounds and Audio Devices. There should be a box to check there that will show up the speaker icon down by your clock.
Best of luck..
Nov 18, 2010 | Dell Dimension 2400 PC Desktop
How do I set my clock on the computer
On a Windows PC, you can double-click on the digital clock down in the right-hand bottom corner and a dialog will pop up allowing you to change the date, time, etc. If the clock does not appear in the system tray (bottom-right), then open the control panel from the start menu and double-click 'Date and Time'.
Sep 08, 2010 | Computers & Internet
How do I set my clock on my computer? It says that the time is 6:45PM when it is actually 9:36PM eastern stander time..
double click the clock/time in the system tray in the lower right of your computer screen, then click on the time zone tab and select the eastern standard time zone and tick off the box in the lower left of that box for the automatically adjust for daylight saving time, then select apply in the bottom then ok...now recheck your time..it should now read the correct time.
bill
Jul 16, 2010 | Dell Dimension 3100 PC Desktop
How do i transfer digital photos from a picture cd to a memory stick?
Hello.If your using windows xp just put the cd in the drive and plug the memory stick in. Click My Computer and look at removeable devices.Right click the CD drive and then Open.You should see the pictures or information about them.Go to Edit at the top right corner of the screen click it and then click "select all". Click Edit again and click "copy to folder".In the next box look for your memory stick it will be Removeable Drive E: or F: or some other letter near that.Click it to highlite it and click copy at the bottom of the box. When you remove your memory always click safely remove hardware icon by the clock on your desktop. Other versions of windows are similar in process.
builderdale
Feb 28, 2010 | Kodak EasyShare One Digital Camera
When we have our Sony Bravia on AV input, it displays a clock at the bottom right. How can we stop this?
It is On-Screen Display. Press Info " i " button on TV remote so on-screen display will disappear.
Thanks.
Oct 02, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
