Question about Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive
I can`t see the harddrive from my PC
I`m running XP, and plugg\ing the buffalo portable HD into a USB port. First time it worked fine, but now it just doesn`t work.
  • 4 Answers
Try looking for the drive in the "Disk Management".
Right click on "My Computer" or "Computer" and select "Manage" then select the "Disk Management" item.
If you can see the drive, but there is no drive letter assigned, you may need to format it for your operating system or create an accessible partition on the drive. You can access all these options by right clicking on the drive from the "disk management" screen that you should be on.
mine needed to be initialized (by right clicking on it) and then i formated it
Good Luck!
Posted on Oct 26, 2008
Have recently had to add windows 7 to my PC (losing everything) but have laptop using XP. When I plug buffalo ministation into PC it wants to format but I'll lose everything on harddrive won't
click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Oct 12, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo 1TB portable hdd, in properties,it says that the file system is unknown, do I need to format it, if so is FAT 32 ok, I am running XP
MY BUFFALO HD IS NOT WORKING WORKING TIME ITS VERY HOT AND AND THAN DISCONNECT PLS SOLVE MY PROBLEMS MODEL N0.HD-PXT500U2 S/N- 75570914513605
email-artistarif1@gmail.com
094116987687
Oct 29, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
My external hard drive (BUFFALO HD-PE320U2) is not working. When I plug it on the computer "safely remove hardware button" display on taskbar but no partition display on My Computer. What will...
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Sep 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My external hard drive started to make rRrrrrRrRRrRrrrrrr sound and now my computer cannot detect it and no icon appears, it has been working for months and now it wont work. if i click the hard drive or...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 10, 2011 | Buffalo Technology Buffalo DriveStation...
My Buffalo HD-PX320U2 External Hard Disk have a strange problem, after I've input the password the computer won't recognize my storage drive
Dec 11, 2010 | BUFFALO hop 320GB MINISTATION METRO(...
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
I have a 500GB unit - my computer, running Windows
maybe you need to reinstall usb drivers. did you check device manager to see if any conflicts exist?
if you need help doing this please reply. good luck
May 13, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
I have a 250GB Buffalo Turbo USB Hardrive. Until today it was working fine. Now suddenly it says USB Driver not recognized. Whats the problem?
Try to insert it to the other usb ports and see if it works fine. If it doesn't, then probably there is a problem with it. But try to insert other usb devices in the usb ports of your computer, if it does'nt recognize also then the problem is in your usb ports.
Oct 30, 2009 | Buffalo Technology 250GB MINISTATION TURBO...
Portable Harddrive - Works on Newish Lappy, not on old Thinkpad
Time to install an XP driver for your PCMCIA card.
Sep 15, 2008 | Computers & Internet
Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive Logo
372 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
