Question about Directv Televison & Video
Programing directv remote to a digital research tv
Directv remote won't work on digita reserch tv
  • Sam king Feb 17, 2012
    directv remte will not work on digital research tv
cammykins
  • 149 Answers
SOURCE: Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Posted on Sep 24, 2007
Gigatech
  • 259 Answers
SOURCE: Tivo DirecTV Remote-Program AKAI LCT2721AD
Here is the manual:
http://www.directtv-advisor.com/support-files/direct-tv-remote-manual.pdf
Posted on Dec 10, 2007
jdaniher
  • 34 Answers
SOURCE: program Directv remote to operate the Proscan TV
The Proscan is an RCA product so the codes are:
10047, 10466, 11347, 11447, 10018, 10019, 10038, 10047, 1090, 1135, 10679, 11047, 11147, 11247, 11347, 11447, 11547
1. Turn on the TV
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under TV flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of TV being set up. If performed correctly, the green light under the selected position lashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
If this helps please rate my response. Have a wonderful day!!
Posted on Jun 27, 2009
SOURCE: Remote code Directv
try vizio under tv tv brand in the direct tv remote control codes.
Posted on Feb 13, 2010
SOURCE: Samtron TV problems
10702 code for samsung worked for my samtron tv.
Posted on Apr 18, 2010
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
on Jun 10, 2010 | Televison & Video
Tip
  1. Turn on the TV.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
I have a 27" sylvania
no solution here just sounds like the remote is programmed but not with the correct code or frequency hence why power won't work but volume does, if it's a universal remote try programming it again, also try looking at the manual to see if there's something like a mini breaker box, some remotes like garage doors have a panel of switches in them, sometimes a-b like a baby moniter, anyways look in the manual and see if there is one of these or something like that and maybe it just has to be redone there. good luck sorry if none of these work or can be done.
Sep 13, 2011 | Sylvania Televison & Video
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
code.
OK.
Jul 06, 2011 | Televison & Video
I can't program my direct tv remote to my coby TFTV3225 TV. Don't have the right codes. Does anyone know the codes?
11531 is the code given by DirecTV for this model. To enter this code . . .
1. Slide the mode switch at the top of the remote to the TV position
2. Hold both the MUTE and SELECT buttons until the LED blinks twice
3. Enter the 5-digit code 11531
4. Test the volume and power buttons for correct operation with the TV
If the code does not work first time, try entering the code a couple more times. If it still doesn't work, also try code 11436. DirecTV do not list any other codes for your TV, so if they don't work, it's possible that the remote will not work with your TV. There is also a code search option which tries every code in the remote. If this doesn't work, the remote definitely will not work with your TV.
Please try the codes above and let me know if you need further assistance or the code search instructions. Also, remember to slide the mode switch back to the DirecTV position after you have finished entering the codes.
Regards,
BElectric
Apr 24, 2011 | Coby TFTV3225 32 in. LCD TV
TV Remote code issues
If you go to Directv.com and go to the remote control programming section you can put in the make and model of the tv and it will usually come up with a specific code that may work. I hope this helps a little bit. :)
Mar 31, 2009 | Panasonic EUR7603Z9A Remote Control
I have a Directv RC24 remote control. I am trying
1. Locate the DIRECTV Receiver's brand and model number
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
6. Using the number keys enter the 5-digit code. If performed
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
How can i program my rc16 direc tv remote control to my philips tv
1.Press menu on your remote and then go to settings and press select on setup.
2.Go to remote and then go to reset remote.
3.Press and hold MUTE and SELECT until the light above the mode on tv switch on the remote flashes twice.
4.Enter the code using the numbers on your tv.
5.you have cleared AV1,AV2 and tv modes.Move the switch back to DIRECTV;press select on done.
Jul 10, 2008 | Directv RC23 Remote Control
Directv remote codes
10556 worked for my 32" digital research lcd.
Nov 08, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
80 people viewed this question
Top Directv Televison & Video Experts
john milligan
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
