Question about Sewing Machines
How do I get the oil light off a bernina 530. I have oiled and reset the stitch counter but the oil light is still on.
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
  • 21 Answers
SOURCE: I have s Bernina deco
Your timing is out in the bobbin area this will have to be reset, maybe the last time that you used it you had a cotton jam, and it was pulled out of alignment.
Posted on Sep 02, 2008
  • 19 Answers
SOURCE: how do i oil my bernina 801?
Please do not oil anything with WD40, it is an alcohol based cleaner hense why it's flammable. No where on the container will it say anything about lubricating, it will merely dry out your machine. We use it, but only to clean metal parts... we then clean it off and let it evaporate for a day before applying oil.
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
  • 19 Answers
SOURCE: Bernina 930 where to put oil
  • 166 Answers
SOURCE: How do you oil a bernina 1008??
Probably the most important is the inside of the hook ring. Remove the bobbin case and open the hook retainer by pressing the catch on the left-hand-side. The hook can then be removed by just gripping the shaft on which the bobbin was mounted and removing the complete hook. NEVER OIL BEFORE CLEANING. This is the single biggest problem I come across - continually oiling any kind of machine without first removing the old, contaminated lubricant will attract grime. So ... get yourself a few cotton buds and carefully clean around the inside of the hook ring (the circular aperture where the hook was), paying particular attention to the small groove running round the outside. Rotate the handwheel to bring the hook driver round halfway to allow the whole hook ring to be cleaned. Use the opportunity to remove any clogged lint and grime that may have built-up on the underside of the stitch table. WHen you're satisfied it's all clean, then run a very light bead of oil around the groove in the hook ring, turn the hand-wheel fully to bringthe hook driver back to the left-hand-side and oil the other side of the hook ring. Before replacing the hook, take a good look at the groove that runs around the back side of the hook near the edge and thoroughly clean that too, before smearing a drop of oil around that edge with a finger. Replace the hook, making sure its properly seated in the hook ring and click the black plastic cover back into place before replacing the bobbin case. Your machine should now sound a great deal quieter, if you haven't done this for a while !! Good Luck !
Posted on Feb 17, 2010
My Bernina 530 is not stitching as nicely as it has been even with the walking foot. Had 3 months and have had super results until today. New needle, rethreaded, re did bobbin, cleaned all lint away
It is the older mechanical Bernina 530 Record or the newer computerized Bernina 530?
The mechanical model may need a thorough clean and oil.
Without knowing exactly what symptoms the machine is exhibiting, we are limited in our ability to assist.
Mar 17, 2017 | Bernina Sewing Machines
Tip
Bernina 530 through 830 Record Oiling Diagram
Photo shows location of oil holes for Bernina 530-830 Records.
on Apr 03, 2015 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Red light system will knot come on
Is it a Bernina 930 Record (a mechanical machine)? If so, have you cleaned and oiled your machine recently? Could be some of the moving parts have dried out and are sticking. Use only fresh good quality sewing machine oil and apply 1-2 drops of oil each spot (note--there are a lot of oil ports in the machine that will help keep your machine working). The problem you are experiencing probably emanates from the stitch selectors at the top of the machine, so be sure to oil and exercise those. Do NOT oil plastic parts, belts, cams, and stay away from the Bernina basting stitch at the middle of the needle bar.
You should apply a drop of oil at the shuttle/hook area every time you install a new bobbin, perform a thorough clean and oil every 40 hours of sewing or, if in storage, every six months.
Bernina 930 oil guide:
Jan 03, 2016 | Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Oct 19, 2015 | Bernina Sewing Machines
How do i wind a bobbin on a Bernina 530-2 sewing machine?
Bobbin winding diagram:
Bernina 530 Sewing Machine Threading Diagram
Owner's Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwi-3auhyNXJAhXnoYMKHfKEAXoQFggpMAI&url=http%3A%2F%2Fdolfmeister.com%2Ffiles%2Fsewing_machines%2Fbernina_530-2_record.pdf&usg=AFQjCNH6EmIkDwhmwEVQDYxOehZEyI-8AA&cad=rja
Be sure to oil your machine regularly. Use Fresh "good quality" sewing machine oil. Apply 1-2 drops of oil every place shown in the instruction manual (look for the little oil ports/holes). Do NOT oil rubber, plastic, leather, or belts.
Jul 15, 2015 | Bernina Sewing Machines
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
My wheel will nor turn and my machine will not sew on my 930
sounds like it's time to have the sewing machine serviced.
Feb 07, 2013 | Bernina Sewing Machines
My 1008 bernina sounds like it is straining to
Your machine needs to be serviced. Take it to an authorized Bernina service person.
Feb 17, 2010 | Bernina 1008
Bernina Record 930 Electronic, seldom use, like new. Wheel will not move. Was doing stright sewing, machine slowed down then froze. Maching is clean. No instruction book or manual. Machine belongs to my...
Bernina 930 Records are notorious for the basting stitch sticking which eventually locks up the machine. To prevent this from happening, be sure to run the basting stitch for a few minutes every month. If it is stuck, you'll need to take it to a Bernina technician.
If it is not the basting stitch, it could be a broken plastic gear (trip to the Bernina technician) or it needs oiling.
If it is not a broken gear, then it probably needs oiling. Your Bernina mechanical requires regular oiling and cleaning even if you don't use it (ie, every time you change the bobbin, every 8 hours of sewing, or every 6 months if not in use). HINT: recommend Bernina oil or similar good quality oil for mechanical machines, NOT 3-in-1 oil, WD-40, or cooking oil!!! One or two drops of oil in every oil hole and every place that metal part rubs against metal part.
Treat your Bernina well and it will serve you well for many years.
Oct 23, 2009 | Bernina Sewing Machines
Sewing Machines Logo
89 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
