Question about HEWLETT-PACKARD HP G71-445US Notebook
Somehow, my wireless assistant got turned off. I have a HP G71-340 Laptop. How do I turn the wireless assistant back
HP Pavilion DVX7 Airplane mood turned on, how do I turn it off?
Remove drivers. Restart. Reinstall drivers. Restart. Check if wireless is enabled in BIOS. Be sure there is no button on the laptop to turn the wireless on.
Mar 31, 2013 | HP Pavilion Computers & Internet
I have a HP pavilion entertainment PC laptop.The wireless button of my laptop has turnedd off and not getting on.Please help me.
hpweb_1-2_minus.gif Wireless device is turned off or disabled The power to the wireless network and Bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02448899.jpg and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02448900.jpg will display.
  3. You can also try pressing the fn+ F2 keys simultaneously to enable the wireless device.
Apr 24, 2011 | Computers & Internet
Hi, my wire less internet was working and now i cant get it to work. on the icon on the bottom of the screen when you click on wifi it has a red cross on it.it says something about the setting is turned...
It sounds like your WiFi switch was somehow shut off.
  3. Or you can try pressing the Fn and the F2 keys at the same time to enable your wireless adapter.
  4. Here is a link for your product support page at Hp.com : http://h10025.www1.hp.com/ewfrf /wc/searchResults?tmp_product=Compaq+Presario+V6000T+CTO+Notebook+PC&product=3177516&tmp_qt=turn+on+wireless+switch&lc=en&dlc=en&cc=us
Apr 21, 2011 | HP Compaq Presario V6000T Notebook
I am having trouble connecting to the internet because my WLAN has been turned off, how do I turn my wireless back on?
From the HP website:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 18, 2011 | HP Pavilion dv4000 Notebook
My hp presacio cq60 wireless button won't turn on.. Keep saying lwan is disable.. How do I fix this ,, thanks . Tried turning it on for a while
1. Press wireless button. 2. left click the dialog box in the bottom right corner it will prob say wireless disabled etc. 3. HP wireless assist box should open if so its working and you should click on properties. 4. check all unchecked boxes and press apply or ok etc.5 you should now see in the top right corner of the HP wireless assist box an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Jan 07, 2011 | Compaq Presario CQ60-220US PC Laptop
I can't switch on wireless for my laptop.. i press fn/f2 but still nothing happen.. so, i wonder if my wireless button does not functioning anymore.. if it does happen so, what else can i do to switch...
In order to switch wireless on there is a Wireless assistant available in your Control panel like I am using a hp laptop so there's an HP wireless Assistant available in the control panel. Open it and there will be a WLAN option. Simply turn it on !!! Bingo !!!
Sep 24, 2010 | Acer Aspire One PC Notebook
Recently downgraded to windows xp from vista, Atheros wireless will not turn on automaticcal when computer is restarted. At the windows loading screen, the wireless light turns blue for 3 seconds and then...
I had this problem too. You need the HP Wireless Assistant. Download it here- ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36770.exe
Once installed, open the HP Wireless Assistant and click Properties button. Check the box next to "Independent controls for installed wireless devices." Then click "Turn All On" button. On next boot it will be enabled!
Sep 07, 2010 | HP Computers & Internet
Wireless button doesnt work
If the wireless light is amber even if you turn on the wireless light, then follow these steps
1. Go to device manager, Under network adaptor check for the wireless driver eg- Broadcom Wireless LAN Driver or Atheros Wireless LAN Driver, if present then right click and uninstall and choose uninstall then follow step 2, if not present then follow step 2.
2. Search for recovery manager under all programs, click advanced tab - select driver download and click next - choose the driver(ie - boradcom or atheros) - click install - restart the computer.
Then check the wireless light.
3. Do a bios update of the notebook.
(http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-74823-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795407) then restart and check.
4. If still no go then Reseat the wirless card on your notebook.
Situated at the bottom pannel of notebook ,you will find a compartment with a image of tower with signals unscrew that compartment and the carefully remove the wireless card and put it back again and repete the step 2.
Mar 31, 2010 | HP Pavilion dv7-1130us laptop
HP Pavilion dv4000 computer, wireless button disabled
Go to the control panel, hardware, device manager. Uninstall the wireless adapter then restart the laptop.
You can also download the HP wireless assistant:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-33346-1&cc=us&lc=en&dlc=en&product=468789
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Computers & Internet
I just had the same problem with my wife's HP Pavillion dv6000 laptop.
It was working fine, then just stopped recognizing the wireless card. My daughter had been using it, so I was in doubt as to what had/hadn't been done to it software-wise (virus?). So I ran the complete recover to restore everything to the state when it was new.
Still can't recognize the wireless. The indicator light stays orange no matter which position the switch is in.
So I google "HP dv6000" looking for a manual, and the FIRST thing I find is a Recall notice http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277 Yeah, I know, they're covering their butts by calling it a
"Limited Warranty Service Enhancement" but they basically know that these machines were defective from the date of manufacure. They told me that my machine didn't qualify for the free service because it was 9 months past the warranty extension and tried to get me to shell out $250 for a new mother board.
Maybe I'll try the external wireless card solution, but it sounds like the MB will probably go bad next. I've owned a bunch of HP computers (have four of them working in the house right now) but I'll probably be looking at Dell next time around.
Jul 27, 2008 | HP Pavilion dv6000z Notebook
HEWLETT-PACKARD HP G71-445US Notebook Logo
42 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
