After i changed batteries and pressed on button , mt Ti-86's screen like tik tac toe
How to Change the Brightness of the Display
To darken the display, press the yellow 2nd button and then press and hold down the Up-Arrow button located in the upper right section of the keypad. Release the Up-Arrow button when the display has reached the desired level of darkness.
To lighten the display, press the yellow 2nd button and then press and hold down the Down-Arrow button. Release the Down-Arrow button when the display has reached the desired level of lightness.
As you go through this process, a number will appear at the top right corner of the display. If this number is 7 or higher when your screen reaches the desired level of brightness, then your batteries are getting low and may need replacing soon. This number will be approximately 3 or 4 for new batteries.
