Question about Panasonic Televison & Video
Th-46pz80u 10 blink code
Won't turn on, 10 blink code
5 Suggested Answers
  • 11800 Answers
SOURCE: i have a Panasonic TH-46PZ80U
This is the board
http://www.partstore.com/Part/Matsushita/Panasonic/TH46PZ80U/Matsushita/Panasonic/TNPA4439AKS/New.aspx
Posted on Jun 15, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a Panasonic model
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Posted on Jul 18, 2011
diodeic
  • 1622 Answers
SOURCE: My 50" panasonic only blinks 10 times but
The main cause of this power up problem are bad capacitors on your power if the capacitor is bad. See more bad capacitor image
Now, if your LCD set is still under warranty I would suggest to use it and let the professionals handle the problem for you. But for the rest of the Samsung LCD TV owners that their warranty had expired and want to save some money, this would be the best route. Mind me, when I fixed my power supply I didn't have any previous experience on desoldering and soldering capacitors on a power supply board. It was a good experience after all is said and done.
Now lets talk about the specs, capacitors hold 3 important value:
1. The capacitance measured in uF(micro farads) (ex. 2200uF), 2. Voltage (ex. 10v), 3. Temperature (ex. 105°C)
I hope that this will help to solve the problem and do take care because it contains high voltages...
Posted on Aug 08, 2011
caroldon
  • 17129 Answers
SOURCE: pioneer red standby light blinks
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using fixya.
Posted on Aug 22, 2011
8 BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 03, 2014 | Panasonic Video How to Fix Etx2mm704mgh 10...
PANASONIC TV MODEL # TH-46PZ80U BLINKS 10 TIMES
had the same problem with my panasonic, it was a faulty power switch, its a common fault with them
Dec 31, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Th-46pz80u 10 blinks red light
Power supply or something loading it down.
Jun 12, 2012 | Panasonic Televison & Video
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
TC-P50GT25 won't turn on
10 blinks check sc board for a short circuit in the mosfet ,replaces SC board
Mar 27, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
