Question about Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver
Won't stay on track
When I set theautopilot it will work for a few minutes then it starts to turnaround and around and won't track. I was told you can set the "pots" to correct this . Can anyone help?
  • plucker Nov 20, 2007
    motor is trying to turn full time even though foot pedal is removed and battery is fully charged.
  • huntncoon Apr 27, 2009
    I have the same exact problem where the trolling motor will spin around in the autopilot mode. I have repalced the control board assembly 3 times. Each time it has worked for a couple months then it starts acting up again.
I doubt it is the foot pedal. Mine did that for years and I would touch the foot pedal and it would stop. Usually happened towards the end of the day when the battery was flatter. Recently it started turning full time - when the foot pedal was tucked away under the boat and not connected. Foot pedal has no control of this function when it is connected.
Posted on Nov 20, 2007
  • plucker Dec 29, 2007
    I would presume that the compass is in the early stages of collapse. You will probably get a fair bit of time before it dies on you though.
    The compass is located in the head of the unit where the autopilot button is found
You need a new foot petal
Posted on Aug 11, 2007
Kobelco 120 excavator sometimes one track will not drive.
Filter or pressure relief valve, or track feed valve. Otherwise you are in for a big bucks drive motor.
If it were the pump you would have bad everything.
May 11, 2015 | Cars & Trucks
Acura Legend 86 wont start after initially running fine
fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
May 13, 2017 | 1986 Acura Legend
I have a 3 month old corolla 2012 le automatic. The engine temperature stays below C when I start the car in the morning and heating doesn't work. Even letting the engine run on idle for a few min
You need to have the dealer look at this, if you fool around with it you can void your warranty. Toyota looks for any legal excuse to void the warranty.
Dec 06, 2012 | 2012 Toyota Corolla L Sedan 1.8L 4-cyl....
I have a 2003 hyunday accent I just got and the cd player not working. I put the cd in and it won't change tracks or play and when I try to change tracks it makes a weird noise?? Idk what to do pl
id take it to the dealer ship and tell them or me personaly id replace the stereo deck it sound like the eye on the track inside is jammed id maybe try putting a can of air duster in it and blow it around that may work or take it in to some one who can professionaly cleen it but either way you may be told to replace it
Sep 23, 2012 | Hyundai 2003 Accent Radio
Oven won't stay on
I would say a fuse in cuircit board or something in the mother board
Dec 19, 2011 | Bertazzoni X30 4 GGV X Gas Kitchen Range
Hello, I have a Echo PE-200 that won't stay
You definitely have carb. problems. The fuel probably varnisized. In this case, you may have to place the carburetor in carb. dip for a few hours.
Try my Tip out:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Aug 05, 2011 | Echo Garden
My 2004 ford expedition was runing perfect when I got home and parked it in the driveway few minutes later I tred to start it and it looked like it was running out of gas started to shake and the engine...
Hello You will have to reset your fuel pump switch located passenger side right foot kick panel when you press it it should stay down if this does not work your probably looking at a fuel pump not working.
Jan 06, 2011 | 2004 Ford Expedition
POWER SEATS WONT WORK
We had this problem numerous time (luckily while under an extended warranty) our local dealer tried fixing it many times, they even put a heavier motor under the seat. After one repair the seat motor stopped working within 2 miles. My husband turned around stayed out in the shop and helped the mechanic discover that when the seat went back at a certain point, the wire under the drivers seat was routed so that it traveled into the seat track and back out, when it went into the track it got pinched and shorted out. (you CAN NOT tell if this has happened by looking under the seat, the wire will NOT still be trapped in the seat track or severed, at a certain point the wires traveled into and then back out of the track causing a main wire to short out (wires are harnessed under the drivers seat which control movement in both seats). The solution - a new wire harness was installed and the wires had to be routed differently to prevent this from happening. The repair only took a few minutes the wire harness had to move over about three inches and the wires got ties to hold them out of the way. That was three years ago and so far this has not been a problem again. Hope this helps, or gives you some place to start looking.
Aug 30, 2010 | 2005 Chrysler Pacifica
RCA,RP9328A,Audio System
I did the following to set the clock:
1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
2. Press Set/Demo. The hour indicator on the clock should start blinking.
3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the hour.
4. Press Set/Demo. The minute indicator on the clock should start blinking.
5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the minute.
6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
Feb 09, 2008 | Audio Players & Recorders
Loose Sound and Picture very now and then, but TV stays ON
Check out www.manualsparadise.com There are service manuals available for download. They start at $7.95. That might point you in the right direction.
Oct 12, 2007 | Pioneer PRO-510HD 53" Rear Projection...
GPS Logo
382 people viewed this question
Top Minn Kota GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
