Question about Sharp 15" AQUOS LCD Flat-Panel LC15B4US Monitor
How do I reset my Sharp LC15SH6U
I need to reset my tv, but I can't find a reset button on the outside.
4 Suggested Answers
satavlad
  • 405 Answers
SOURCE: I HAVE A 15 INCH SHARP AQUOS TV IT IS ABOUT 2 1/2
LCD panel went bad, not repairable for economical reasons.
Posted on Nov 30, 2009
jdvillanueva
  • 2098 Answers
SOURCE: Sharp Aqous 52' opc &
Hi patricia_597,
Unplug the unit from the outlet, then while unplug, press and hold the power on button for one minute to drain the voltage and refresh the boards...
Try to open again and see if the symptoms remain the same...
If yes, the power supply board produced an out-of-regulation condition and disable the unit. The most common caused of this symptom is the leaky/dried filter electrolytic capacitor in the output of the power supply section. It will drop the voltage from normal and trigger the blinking of the led light. It will not power up unless isolated the faulty parts.
Leaky capacitor sometimes has a bulged/dome at the top but not all. Dried capacitor has no physical indication of fault and looks new and in good condition but actually not. You must have a capacitor checker to determine its condition and pinpoint the faulty one.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qulified technician to isolate the symptoms..
Also check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back panel because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 25, 2011
SD Tech
  • 14553 Answers
SOURCE: my control panel are locked on my 55'' sharp tv
First if the set has a lockout feature for the keyboard and or remote(it could have either or both) Instructions for release are in the owner manual--read every page to find out.
If no manual Google the model number with "manual" to try to locate a free one.
Last resort is call customer service for Sharp and have them step you thru the process.
Posted on Dec 05, 2012
Remote control select buttons not working
First replace the batteries in the transmitter. If that doesn't work you may need either the transmitter, or the IR PCB & possibly the MAIN PCB(this is the IR board & MAIN inside the TV for which you will need the TV model#)
See the following website for transmitter :
http://www.amazon.com/s/?ie=UTF8&keywords=sharp+gb004wjsa&tag=googhydr-20&index=aps&hvadid=27053766363&hvpos=1t1&hvexid=&hvnetw=s&hvrand=13949172362774600291&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_40f8n9hcep_b
Mar 04, 2015 | Sharp Aquos Televison & Video
My sharp tv reset for code k
Press Ch Down & Vol Down button from LCD Panel.
You will get 1/9 page on screen.
Go to 9/9 and run EEP by pressing Ch Up and down button from remote.
Dec 07, 2014 | Sharp Televison & Video
How do I get to ch 3 on my sharp 13f-m50?
Try this:
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
You will have to look around the menu for the reset option to default to ch 3. Be careful. You are in the service mode.
May 14, 2014 | Sharp 25N-M100 25" TV
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
Sharp LC-32D43U LCD TV doesn't turn on after a shut off but will after reset.
This is a typical memory problem. Better refer it to a qualified service technician.
Jul 19, 2012 | Televison & Video
Spray washed outside of the unit with a garden hose - now when I plug unit in, the reset button at the plug immediately trips - I let fully dry overnight but reset still trips upon plugging the unit into...
Obviously, one of the electrical components is still wet or got damaged by the garden hose washing. Until you remove the unit from the window or wall and dismantle the cabinet, there's no way to know what damage has been done.
I'm sorry, I wish I had a quick fix solution for you. But, there just isn't one, short of replacing the entire unit.
Jun 01, 2011 | Sharp AF-S85FX Wall/Window Air Conditioner
What is my sharp code
Hello
To get into the service menu do the following.
Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
After entering to the service manu, goto V-Chip options and Unlock it. You have to reset all V-Chip options after resetting it. OK.
Dec 19, 2010 | Sharp 32C-240 32" TV
Broken lcd
it would be cheaper to buy a new one
Apr 22, 2009 | Sharp LC15SH6U 15 in. EDTV-Ready LCD...
Sharp 15" AQUOS LCD Flat-Panel LC15B4US Monitor Logo
42 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
