Question about Locks & Locksmithing
Need to put a 3 number code into a new unican lock
  • 963 Answers
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Feb 17, 2012
SOURCE: change to lock number
I fixed it. thanks
Posted on Apr 06, 2009
  • 32 Answers
SOURCE: i need to change the code on my unican ll1011
Copy this address into the address bar on your web browser http://www.tharstonconsultancy.co.uk/html/body_code_change.html You will find detailed instructions for the change. Please rate this answer,thanks.
Posted on Apr 11, 2009
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
aspx?id=13
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: how can I put a
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the grid that the highlighted link above takes you to, then go to the far-right column for 7000/7100 " Tips" and click on PDF, which will download the PDF file of the reprogramming instructions that you need. Again, you will need Adobe reader to view this file.
Posted on Jul 26, 2011
How can I put a new code in a unican 7000 when I dont know the original code
Jul 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
My kaba gun lock will not open i put new batteries in it i have tried 3 different one but nothing will work. i try to punch in my code and it just peeps at me and i can not get into m gun safe.
I don't have a direct answer, but Kaba customer service can be reached here:
Mar 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to change combination but lost control key. Whay can I do?
Go to your nearest locksmith and have him make you a key to the code, "DF59". That's the key you need.
Dec 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
Lost code for unican 1000 i have lock of but dont
Click below to get to the manual you need. when you get there find your model number and slide across the page till you get to the PDF under the Manuals column. Click again and either save or open the file.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Sep 29, 2009 | Locks & Locksmithing
Lost code for keyless unican lock
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
I need to change the code on my unican ll1011
Apr 11, 2009 | Simplex Kaba Ilco Unican 1011 keyless...
Want to reprogam keyless lock unican push button lock please advise ------thankk you...
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Dec 31, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
52 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
