Question about RCA R52WH73 Projection Television
TV WOULDN'T TURN ON
After a series of power outages my RCA R52WH75 52" tv wouldn't turn on. What do you think may have cause this problem?
  • 56 Answers
It could be a blown fuse check those first if its not that something might have been fried from the power outages
Posted on Oct 26, 2008
I have an lg 26lx1d tv, suddenly red light bottom of screen was gone and then wouldn't turn power on.
  • Jeramie 36 solutionsMar 23, 2011
Replace capacitors c520 and c126 to get your power working again.
Also make sure that you don't have a broken green 3 inch jumper wire broke that lies under the heat shield in the top right corner. The wire should be glued to the board for stability. It sometimes breaks loose and will cause the TV screen to stay off.
Aug 28, 2012 | LG 26LX1D 26 in. LCD HDTV
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
TV suddenly shut off - and now won't turn back on. Screen went totally black. When you try to turn it back on, screen stays dark, and tv has a humming sound that wouldn't shut off until unplugged. Not...
Did this unit fail after a power outage or passing storm? If so could be lost of component in the low voltage power supply circuit or degausing relay circuit. I would strongly suggest you seek help from a qualified repair center. Don not attempt to repair yourself...to dangerous.
Feb 18, 2011 | RCA F32650 32" TV
It goes off and u can get it back on ,,you have to keep turn it off and on before it will ever come on and stay.. lots of bad reviews on this brand RCA model D52W20 SHOULD BE A RECALL ON THIS BRAND TO...
RCA Scenium HDTV (Model #: D52W135D)(Chasis # ATC221) WILL NOT TURN ON!! When plugged in after a while of being unplugged the front power light will flash green lights first once...then 9 more times. I can hear the static in the back but nothing will turn on. It really sucks becuase we were just watch yesterday, turned it off after a while of it being on(I don't know if that matters) then the next day in the morning I tried to turn it on and it wouldn't turn on... :Z PLEASE HELP!!
Feb 16, 2011 | RCA D52W135D 52 in. TV/DVD Combo
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
Tv won,t come on now
i have a kp51ws520 that i just fixed. it blinked 9 times. found out it was the g board. got it done pretty cheap . let me know if you need more info.
Feb 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
Rca d52w20
if you had a power surge from the outage it could be anything. disconnect from the house power and try again in an hour.
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
RCA R52WH73 Projection Television Logo
149 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
