How do i change the input source on my hp 2009m monitor from DGI to VGA
  • 31 Answers
SOURCE: Hp w1907 Monitor going to sleep
try the link provided
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061509&cc=us&lc=en&dlc=en&product=3351967
Posted on Sep 15, 2009
  • 3287 Answers
SOURCE: W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Posted on Sep 29, 2009
sbluegoldie0
  • 5 Answers
SOURCE: monitor comes up with error check video cable on
you will need a new video card for your pc
Posted on Oct 25, 2009
  • 156 Answers
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Posted on Nov 30, 2009
SOURCE: I have an HP 2009m monitor. When I try to have
Annihilata, I don't think that is the problem. I stumbled across this page while looking for a solution to the same problem. My monitor is set to the native resolution of 1600x900, yet the picture is distorted. It is particularly noticeable with small type, which appears compressed in some areas and stretched in others. I have tried updating and reinstalling the drivers with no success. Then, miraculously the problem seemed to fix itself one day between when I logged off and my GF logged in. Everything remained in the proper proportion for a day, and then as mysteriously as the problem had fixed itself it occured again. The display settings have remained constant the entire time.
Posted on Jan 24, 2010
I have a hp 2009m monitor and i want to connect it to an emachines t6212
Verify you have connected the VGA cable to the VGA output of the computer.
Feb 05, 2013 | HP 2009M Monitor
What does dvi mean
Hello figment_of_u,
DVI stands for Digital Video Interface. They are used for direct digital connections between source video (namely, video cards) and LCD monitors. This provides a faster, higher-quality image than with analog, due to the nature of the digital format. All video cards initially produce a digital video signal, which is converted into analog at the VGA output. The analog signal travels to the monitor and is re-converted to a digital signal. DVI-D eliminates the analog conversion process and improves the connection between source and display.
Hope this helps you understand what DVI is for. Thank you for choosing Fixya.
Feb 12, 2012 | HP 2009M Monitor
Double image on screen
Usualy in these cases I check the VGA cable. If you can buy new one, but not cheap one will solve the problem. Just to be sure that this is your problem hold the small vga cable cylinders with your hands for 5-6 seconds. When you release them you shouldn't see the ghost image on your screen. It sounds weird but it works. By holding these cylinders you remove the static electricity of the cable. Try to understand what device around your monitor causes the problem. The cause also may be lot of power cables or power sources near the VGA cable.
Dec 18, 2011 | HP 2009M Monitor
Dvi no signal, vga only. I am using hp1520
I had the same problem ones. You would like to check you display driver.
In 90% cases Windows Driver is not good enough. The best driver for you video card would be the driver you download from the vendor's web site.
You monitor is more likely OK. You can double check that by connecting you monitor to a known working PC.
Hope this helps
Mar 14, 2011 | HP 2009M Monitor
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
I have a hp 2009m monitor and it keeps telling me to check video cable.
Possible causes:
1. Bad cable. Use another video cable that you know is good and test with it.
2. Input source on monitor incorrect. Check to make sure you've got it set to the correct input (VGA or HDMI)
3. Unplug/replug the video cable connections at both the monitor and computer...it could be just corrosion or dust.
4. Hook up the monitor to another computer that you know is working. If your monitor then works, then you know that the video output on your computer has failed. You can also test this situation by connecting a known good monitor w/known good cable to your computer to see if you get video.
Hope that's helpful.
Jan 12, 2011 | HP 2009M Monitor
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
I need a manual for my hp 2009m 16:9 lcd 20'' monitor i need to no if i can connect a vga cord to my monitor and tv
You can find a detailed description how to connect your HP monitor to your computer here.
The 2009m might not have a VGA or HDMI connection (according to this source), but the option to use DVI. So you might have to go and get the correct cable or adapter.
Also look at the bottom of the page for more helpful links.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 16, 2010 | Computers & Internet
Monitor wont come out of sleep mode
I'm guessing you are using a the VGA input of this monitor (the smaller "D" shaped connector with 15 pins) on the back. If not, and you are using the DVI input (larger white connector), then check your PC video output. I've seen this occur with HP monitors when they accidentally get set to "digital" input. Its easy to set that way (even by mistake), but not as easy to reset to analog (VGA). To do that, you'll need to find someone with a DVI output on their video card. Once you connect to a DVI source, the monitir will come on and stay on. You then need to go into the menues of the monitor, find the setting and change it back to "analog". After you do of course, you won't get an image on your monitor until you reconnect to an "analog" (VGA) source.
Jun 02, 2010 | HP w1907 LCD Monitor
I just go a nw hp 2009m and I cant get it to work it clicks on for just a second then goes off It works fine on my other flat screen hanns g
Is your other flat screen bigger than the hp 2009m? If so, it may be set at a resolution that the new monitor isn't capable of hitting. Try changing your resolution before plugging it back in. That MAY work to help you. If it's not that, then for some reason it may just not be receiving an input signal from your computer. You may be able to remedy this by clicking the " MENU " button ON YOUR MONITOR, and selecting the " Change Input Signal "
I hope this helps you.
Oct 14, 2009 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
