Canon ir2800 waste toner replacement give solution
  • 168 Answers
SOURCE: Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Posted on Jan 03, 2009
  • 59 Answers
SOURCE: Changing Waste Toner in CANON IR3245I
Open up the toner cover, undo the screw.
Then on the flat surface under the paper delivery tray there is a round cutout , remove this little cover to reveal a screw, undo this and slide the front cover off to the left. The waste toner bottle is now visible.
Posted on Apr 01, 2009
Cogz
  • 1326 Answers
SOURCE: a message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Posted on Apr 15, 2009
  • 153 Answers
SOURCE: waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
Posted on Jun 01, 2009
iservice
  • 318 Answers
SOURCE: I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Posted on Jun 17, 2009
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
Replace waste toner 9060
actually you must reset the waste toner counter by enter the service mode
Nov 05, 2011 | Canon imageRUNNER 5570 Copier
Canon clc3900 error e013-0002
Hi
In most cases that means that you need to clean/ replace waste toner container, but in worst case scenario:
E013
Cause • Waste toner feeding motor (faulty)
• Waste toner feeding screw (rotation fault)
• DC controller PCB (faulty)
Description
0001 The rotation speed of the waste toner feeding motor has deviated
from a specific value for 0.1 sec or more (PLL signal ‘0’).
0002 The waste toner lock detection switch (SW4) has been pressed for
0.1 sec or more
Aug 28, 2010 | Canon CLC 5100 Copier
What does the display read when toner is out, or toner cartridge is out
If this message appears and you can not make any copy, replace the toner
Original Toner CANON C-EXV3 Black Canon iR2200, iR2800, iR3300, iR3320i.
Oct 30, 2009 | Canon imageRUNNER 2200
E019 CODE ON 6085 CANON
E019As many as 50,000 have been made after detecting a waste toner full condition.Extract the block of the scene and free the container with perfected by toner. Good luck
Sep 20, 2009 | Canon NP 6085 Copier
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
Error code E000019-0000, trying to find out what this error code means.
Hello sir; It's means waste toner bottle full, dump it after you turn off the power, then turn power back on.
Apr 29, 2009 | Office Equipment & Supplies
227 people viewed this question
jasbo
jasbo
