Question about Canon PIXMA iP1800 InkJet Photo Printer
Color ink cartridge out. Won't let me print in black only?
I've enabled Greyscale Printing and set the Cartridge Settings to 'Black Only.' I've also disabled Duplex Printing and Borderless Printing.
Even with these settings, my printer asks for an color ink cartridge if I have it removed, or asks for a new color ink cartridge if I leave it in. I just need to print in black. It won't even let me print a simple black and white text document. Please help!
  • edrickcapili Nov 02, 2008
    same problem here..i only changed the black cartridge but the color is i think half..cant print in black it gives me error of cartridge not installed properly or the cartridge is empty but all is fine..help anyone..tnx!!
    Top Expert:
  • Canon Master
  • 77,499 Answers
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Posted on Jul 21, 2017
  • 6 Answers
SOURCE: Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Posted on Jan 31, 2007
  • 37 Answers
SOURCE: PIXMA iP6220D doesn't use/recognize CL-51 cartridge
Take the photo ink out.
Posted on Aug 19, 2008
  • 508 Answers
SOURCE: document jam, printing is fine, but won,t copy or
check for debris or paper fragments!!!!
Posted on Jun 25, 2009
  • 630 Answers
SOURCE: wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Posted on Aug 22, 2009
  • 739 Answers
SOURCE: printer prints color, but not black even with new cartridge
First thing to do is a head clean then do a test print. Do you see any of the black lines?
If not, don't do a deep clean as this uses up too much ink. Remove the ink cartridges and then remove the print head unit.
Run the print head under a hot tap for a few minutes until all the run off is clear. Take it outside if you can and shake it dry vigourously. You can use paper towel if you like but try not to wipe across the nozzles. Make sue the contacts are all dry and refit it to the printer. reinstall the ink cartridges and print a few test pages - the first couple may well be wasted but then it should start to print properly.
Is the black still missing? If it is do another head clean and another test print. Any improvement? If you start to see some black do some more head clean routines and it may well come back to normal. If on the other hand you see no trace of black at all, it could be that the print head is worn out and needs replacing.
This printer is now of an age where the print head may well be failing. Mine had to be replaced last year as one of the colours stopped printing.
The head is not exactly cheap - but it's cheaper than buying a new A3 printer.
Posted on Sep 10, 2009
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
How to use canon pixma mp 210 How can i print using only black and not having the color ink cartridge in as well? is this possible, or must there always be a black cartridge and a color cartridge installed...
With respect to Canon MP210 color usage during greyscale printing: Unfortunately, with many of the newer inkjet printer models & printer drivers, printing in greyscale actually consumes more color ink than normal draft printing. If you wish to save on color ink, it is suggested to do one of the following as available in your specific printer driver/software:
    -Print in Normal - Draft mode (or super draft if available), plain paper.
    -Print in Black & White mode only* - Draft mode on plain paper (typically this is the best way to save on ink/printing costs).
    -For internet page printing, print using CleanPrint (3rd party software for printing most internet-based content from all major internet browsers. NOTE: not affiliated with Inkjet411):http://www.formatdynamics.com/cleanprint-4-0/
    -Keep printer on at all times; power up cycles typically consume large amounts of ink (per Consumer Reports, Aug 2013 issue).
    * Most printer models will still consume a small percentage of color ink due to normal ink/printer maintenance, such as between job 'spitting'. The purpose is to ensure the printhead is maintained to avoid clogging.
    Regarding Canon PG-30 or CL-31 cartridge repurchase or ink cartridge refilling, if you unable to find a retail / refill store close to you and you are trying to cut ink costs, may we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available to US residents only).
    Here is a link to retail ink cartridge refill stores:
    http://inkjet411.com/?page_id=483
    For any additional questions please contact us directly: Inkjet411help@gmail.com
    -Thank you
Sep 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I have mp210 and want to change my printer to just black and white as I don't do much color printing but my cartridge run's out and I have to keep replacing my color cartridge as well?
1. In Windows: Go to Start>Devices and Printers>Right click on your default printer. Select printing preferences.
2. In the area that reads: Additional Features in the middle of the window, you'll see a selection that reads: Grayscale Printing Put a check in that box. This will print everything in black and white.
3. Go down to the bottom of that window and put a check on the box that reads: Always print with Current Settings.
4. Click Apply
5. Click OK.
Once you are just printing in black and white, the only cartridge you will have to replace is black ink-unless you change it back to color in the future-then you will have to replace the color cartridge as well when it is low.
Apr 17, 2011 | Canon PIXMA MP210 InkJet Printer
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i shut off the colored ink and use only black ink
You can't really "shut off" the color ink with this printer, but you can trick it. If you rarely or never print in color you can put in a full black cartridge and keep your empty color cartridge in the printer. As long as the electronics are still good on the color cartridge your printer will print and won't use any color. You can also set your printer properties to greyscale.
Jan 05, 2010 | Canon PIXMA iP1600 Printer
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
My HP printer stopped printing in color
sure...it is most likely a print settings issue on your word application, maybe. Check that print settings to ensure it's looking for color and not greyscale
Dec 12, 2008 | HP Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
187 people viewed this question
old marine
old marine
