Question about Rockford Fosgate T10001 bd Car Audio Amplifier
Need to bridge rockford fosgate t10001 bd
Trying to bridge amp
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
fkuk
  • 311 Answers
SOURCE: lights up & getting no power to subs
for a test
disconnect everything from the remote terminal in the amplifier
get a bit of wire and connect the remote terminal to a 12 volt supply
does it turn on now?
if yes then check the remote wire from the radio does it become 12v when the radio is on and 0v when it is off
if no make sure that the amplifier has been grounded properly and all the power cables are connected properly
Posted on Dec 31, 2009
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
Lights up & getting no power to subs
for a test
Dec 31, 2009 | Rockford Fosgate T10001 bd Car Audio...
Hi my amp keeps clipping at high volume......i know is not the wiring...can u help me
turn the volume down or the gains on the amp (should be around 3/4 and no more) or get a bigger amp so you do have this problem
Sep 25, 2009 | Rockford Fosgate T10001 bd Car Audio...
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Hello desperate2le,
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
No sound no protection light no obvious problem...
there is a wiring issue in your truck and i would get rid of the preamp
Dec 12, 2008 | Rockford Fosgate T10001 bd Car Audio...
Smoke and no more juice
I Have also had this happen to me, pretty similar around the time it happened to you also, but I'm not just getting my hands dirty and inside the amp. If I fix this, I'll be sure to let you know what it was that I did, or bought and replaced......... I would also like some ideas and support on this if this has already been taken care of
Apr 29, 2007 | Rockford Fosgate T10001 bd Car Audio...
Rockford Fosgate T10001 bd Car Audio Amplifier Logo
59 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
