Question about Kenmore Refrigerators
Model 363.79562990 reset button??
Power to unit but nothing works, any resets??
SOURCE: Reset button or fuse
washer keep draining
Posted on Jan 13, 2008
SOURCE: This is a PS2 Slim model SCPH 79001. Reset button
check the connection, if you have the ps2 plugged in and it wont turn on it would be best to return it or have someone look at it.
Posted on Mar 17, 2009
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
anandg27
  • 1272 Answers
SOURCE: how to do a complete reset of netgear wpn824 v2
Well it seems that you have uploaded the firmware on the router using wireless connection. The firmware on the router has corrupted and now does not seem to be recoverable.
Dude if it is under warranty then get it replaced. To log a complaint with NETGEAR go to this site:
http://my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 08, 2009
  • 2006 Answers
SOURCE: Amana dryer model YNED7200TW will not start. there
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Posted on Jun 08, 2011
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
Nothing happens when I push the power button on the front panel of NAD917 Preamp. Any idea why? Is there a way to reset the box?
Probably a fuse in the unit. Unplug it and open it. If you see a blown fuse, take it out and look at the writing on the metal part. buy a fuse with the same power ratings.
Apr 11, 2016 | NAD Audio Players & Recorders
When powered on, code F60 shows on player and nothing works.turned on and off and also unplugged for 10 seconds but doesn't reset.
With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds. This hoepfully will reset everything
Oct 03, 2015 | Panasonic DMR-ES40V DVD-Video Recorder
Turned of the light on my hood and nothing worked after. No light no fan.
Some units have a reset button on the unit some place Check and see if you have one and push to reset. Hope this works for you.
Sep 15, 2015 | Venmar Kitchen Ranges
RECEIVER PIONNER IS DEAD , no power on
You failed to mention the model number, however, if the unit is truly dead, with slight exceptions, a factory reset will do nothing for you. If you need more assistance, or would like to inquire about repairing your Pioneer, please visit my website at audioserviceclinic.com, and contact me there. Thank you.
Dec 24, 2014 | Audio Players & Recorders
We have a GE side by side the problem is that the only thing working is the lights. No noises, no freezer no cold nothing only lights.
Check the back of the fridge units down near the sealed units for a reset button. If there is one press it an turn on the power. If not you have a problem and will need the sealed units replaced.
Apr 06, 2013 | GE Refrigerators
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
Forgot my unlock pattern
This does not work. I am getting nothing. Please help
Aug 19, 2011 | Coby Kyros 716829701508 Tablet PC
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
Refrigerators Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
