Question about Acer Aspire 5600 Series 5630-6951 Laptop
My Acer Laptop has no access to Billion - BiPAC 7402G ADSL wireless router.
Acer Aspire 5920 Laptop has no access to Billion - BiPAC 7402G ADSL wireless router. The laptop has an inbuilt 802.11a/b/g WLAN.
  • Frank
    Frank May 11, 2010
    when you try to connect to the wireless, does it give you some kind o findication as to what it is looking????
    do you have security encyption on the wireless??
  • Anonymous Mar 18, 2014
    i can access my wireless router but only through safe mode
THE WIRELESS CONNECTIVITY SIGNAL STRENGTH IS VERY POOR
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security core.
Nov 16, 2012 | Acer Aspire 5920-6727 Notebook
Wireless connectivity is very poor to my acer aspire 5920
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security code.
Nov 16, 2012 | Acer Aspire 5920-6335 Laptop
Instructions on how to connect my laptop to my adsl modem wirelessly.i have a 5200g billion router which is connected to my router via ethernet cable.i have a lenovo laptop with bluetooth.
Billion's BiPAC 5200G R4 is an economical ADSL2+ Firewall Router with 802.11g Wireless AP ideally designed for home and SOHO users to enjoy rich firewall security, mobility, and faster speed when using ADSL Internet connection.enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without reconfiguring your laptop with wifi.
Jul 13, 2011 | Computers & Internet
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Have billion bipac 5200n installed on pc aiso servicing 2 wireless laptops . intalled a wireless - g usb adapter (netgear )on 2nd pc now laptops cant access net , saying invalid password any help...
dear sir good day please do reset the device from the sided reset button and the put in the settings for it and make Mac address filter from the wireless management tab and put a pass work on the sec tab so no one can get into your device and use it or bypass the settings ... thank you
Dec 26, 2009 | Computers & Internet
Billion Router Bipac 5102 flashing all the time - ADSL LED- I can not access 192.168.1.254 Mahmoud
Your router code should be 192.168.1.1 OR 192.168.0.1 This should get you to type in your user information and access your options for the router. Reset your router first by holding down the reset button for 10 seconds. Username and Password are both "Admin" If this does not work there could be a problem with your connections. Make sure everything is plugged in correctly and reset your modem as well. If it still doesn't work it is either a problem with your internet provider or your router hardware and you will have to contact the manufacturer. Cheers.
Nov 02, 2009 | Cnet CWR-854 Router
I need to make my acer laptop wireless as i dont know how to do it
first make sure your laptop has the wireless facility then make sure that the wireless driver is installed properly second thing make sure you have an access point which is needed to access other wireless devices...
Oct 09, 2009 | Acer Aspire 5920-6727 Notebook
Is there a way to daisy chain a router onto another and still be able to access both of theire configuration pages? (Billion BiPAC 7401VGPR3 ADSL Router (master) and a D-Link DI-524UP (slave))
you can do the same, however you will have to disable DHCP on the second router and connect the first router to the lan port of the second router.
In this way you can access both the routers and use it on the same network.
Let me know if you need any further help.
Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
