Question about Watches
Having a hard time finding anything about our ridgeway grandfather clock
Ridgeway grandfather clock model # sw112 movement w finish pine serial # 121677 we bought it about 1979 and cant find any information about it
3 Suggested Answers
Nickstar19
  • 417 Answers
SOURCE: How to clean a grandfather clock's mechanism
The Best Thing You Can Use Is Mentholated Spirits Cleans Really Well
Posted on Jul 05, 2008
cmcduncand
  • 714 Answers
SOURCE: My Grandfather Clock loose about 5 minutes about
Rotate the regulation nut on the bottom of the pendulum to the right about 3 turns.
r/
David
Posted on Apr 17, 2010
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    I have a Ridgeway Grandfather clock ser # 95016098 what is the age and approximate value
    from what i can tell, it's a model that is no longer made but was produced from 1984-1991 and depending on production number (the last four of the serial, the first four being the model) they are selling online anywhere between $500-$3000 i would contact http://www.ridgewayclocks.com/ and see if they can give you more detailed information. hope this helps
    May 09, 2016 | Watches
    How to adjust a Hermle grandfather clock?
    you can try this although it may not work with your movement: set the clock at 9 and then move the hands forward past the 12 position. count the strikes. move the hands backward to the 9 position and then advance forward to the 12 position. count the strikes. did the strikes increase by one? if so, keep doing the same thing until your get 12 strikes when you are on the 12. then you can move forward and set the correct time and have the correct # of strikes.
    Jul 25, 2013 | Watches
    Edward Meyer 31 Day Grandfather Clock manual
    I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
    Jan 23, 2012 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    Elgin grandfather clock chimes not working
    I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
    If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
    Mar 29, 2009 | Elgin 0518709FA
    Clock cleaning
    This is not as easy as you might think. We learn decades to repair (cleaning included) watches and clocks. Any tip would be with no use, as every clock needs individual and specific attention.
    The only tip is: visit an eBay and buy the clock repairers book. I've seen some books there.
    All this is under the ''Jewellery and Watches'' section.
    Mar 27, 2009 | Watches
    I inherited a grandfather clock which runs slow
    You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
    Mar 23, 2009 | Watches
    Watches Logo
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
