Question about Garden
Greenfield mower tractor 11 parts manual?
Need to know the length or part number of drive chain the mower I bought is missing the chain so i cant even match one up please help!!!
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
  • 22 Answers
SOURCE: I am trying to get the 11 hp Briggs & Stratton
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Posted on Mar 14, 2009
  • 11 Answers
SOURCE: Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Posted on Apr 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: What is the length of the primary mower belt for a
Many of the parts you can just drop the prefix and use the Sears /AYP #
So, look at the hood sticker or in your manual for the Husq#. 532 18 08-08 becomes 180808 which is a common Sears belt for their secondary belt on the newer 48.
OEP shows as a 5/8 X 89"
The primary for these 174368 (Engine to deck)OEP shows 5/8 X 90.
Best to get the oem if you can. Never tried aftermarket on these.
Also found THIS USEFUL INFORMATION.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 05, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
I need a deck belt for my Murray riding lawn mower model number is 13an772s058
If you still have the old belt, even if it is broken. Taje it to your local lawn and garden center that sells parts and service on riding mowers. Have them measure the belt length and width. If the belt is missing, have them look up belt for the model number of the mower you have.
Oct 13, 2015 | Murray Garden
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
Steering on a greenfield sit-on
adjust it why ??? they normally aren't adjustable
Jun 17, 2014 | Garden
GREENFIELD 8, 11 & 12 HP ANNIVSARY manual
Some manufacturers will not sell the full manual to consumers, perhaps yours will.
Your best bet is to email them with the full model and serial number of your mower with your request:
http://www.greenfield.com.au/contact.html
Jun 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
replace chain -- if it streches length way on floor more than a one quarter of a inch --chain is wore and needs replacing
Huskee supreme 46 " drive belt keeps comeing off..
Hello porkeybyrde3:
You can Use the Breakdown to See if a Component is Missing or Assembled Wrong.
You can View a Breakdown/IPL of this Mower at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers. Then Double Click on the Model in the Results Area. Now you can Select the Section of the Mower you Wish to View.
>>If you cannot Locate the Model, then
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
598 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
