Question about Sanyo 42 in. LCD TV
Where is the fuse located at on a model dp42840 on a 42 inch sanyo tv and wat would it do if fuse is blown my tv cuts on for about 5 seconds and cuts back off
alpug
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
SOURCE: picture is cut off when watching hd stations on my
You can't fix this problem using "pix shape" on the TV itself. To fix this common problem, just change the format on your SAT. BOX using your sat. remote; It should have a format button it. Just keep pushing the format button till you get the whole picture to show on screen and you should be set ...
Posted on Dec 13, 2009
  • 222 Answers
SOURCE: Is there a fuse for Sanyo tv model dp32648?
try partstore.com
Posted on Jun 06, 2010
  • 132 Answers
SOURCE: My sanyo dp42840 flat screen
The first thing I would check would be the electrolytic capacitors on the power supply board. If any of them are swollen or domed on top rather than flat, they will need to be replaced and that will fix your problem. I fix about 75% of them at the shop by replacing caps on power supply. A tech will probably charge around $100 if it is bad caps. It is a fairly easy job.
Posted on Jul 31, 2010
caroldon
  • 17129 Answers
SOURCE: Just purchased new Sanyo 42"DP42840.
Being a new set it is important that you should have tested the model to your liking in the showroom. However some of these models have poor sound as the sound is normally fed into the home audio system. So if you have any audio system connect the audio outputs to the auxiliary and you will be able to get better sound.
Other wise you need to check back at the showroom if the same model sound as same as yours. Otherwise exchange the set under warranty.
Posted on Mar 30, 2011
How do i know if a fuse is blown on my 57in Sanyo TV. They arent tge regular glass ones
What !! A 57 Inch CRT ? are you sure ?
Normally it far more bigger issue on modern LCD/LED tv than fuse.
Apr 14, 2016 | Sanyo Televison & Video
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Model dp46841 sanyo 47 inch tv won't power up
Likely a power board issue. Check that capacitors are OK in the power board, and if blown then replace with exact parts. This is a $10 fix, but if it does not work after than then cost go up like replacing the power board completely.
Oct 06, 2014 | Sanyo DP46841 46 LCD TV 1920x1080, 60 Hz,...
Where is fuse located
It can be located at the main power supply regulator board. You have to open the TV to access it.
Gopakumar Gopalan Google
Aug 09, 2014 | Sanyo Dp32640
Sanyo model # DS32830H, Serial # V3460278431491, Replaced blown fuse, Blew new fuse when turning TV on.
It's faulty to the extent that it's causing repeated fuse blows, so take it back to the store where you bought it, or find a competent service technician
Oct 26, 2013 | Sanyo Televison & Video
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Sanyo  42 in. LCD TV Logo
260 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
