Question about Toshiba Satellite A105 Notebook
Pci serial bus controller on motherboard - Toshiba Satellite A105 Notebook
5 Suggested Answers
  • 10 Answers
SOURCE: toshiba a105-s4054 won't boot
It Sounds Like Your Bios needs Reseting First And see You maybe be having A Tempterature Shutdown. I Just Worked On A Toshiba It Had 2 Different fans 1 For Cpu 1 For NVidia VGA Chip. System Was have major problems Until I Replaced Both fans And They Are Not The same Size They Look The same But One Is Smaller. They Are Hard To Find. Yo ca Always Flash It back To The Prior Bios. Maybe new Bios Won't Operates Properly beacuse Other hardward Changes may Have been Made To The Mother Board ThatYour Board Does Not have. Flash back 1 version First see If That Works. Make shure You have Bios Set For Plug and Play operation. Hope This helps
sosec
Posted on Mar 23, 2008
  • 3940 Answers
SOURCE: Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
Try booting to the system setup (F2 most likely at boot) and resetting the BIOS DEFAULTS, save and exit
Posted on Jul 19, 2008
jennifer720
  • 830 Answers
SOURCE: resource conflict - PCI network controller on
It sounds like your integrated wireless may be malfunctioning. You can disable the wireless from inside of the case and see if it boots up without the error message. If it works, then I would recommend purchasing an external wireless card as a replacement instead of having to replace the motherboard.
You can also try flashing the BIOS but I would definately try solution #1 first. Flashing the BIOS should be last resort!
Please let me know if you have any questions.
Posted on Oct 18, 2009
  • 57 Answers
SOURCE: at start up my pc
Please call your computer manufacturer. Some of the parts of the motherboard is broken.
Posted on Apr 14, 2011
Asus x55u usb 3.0 driver problem
You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
May 20, 2013 | ASUS Computers & Internet
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Dear sir/madam i format my computer from the shop
Check the model of your motherboard and you can find the drivers for that?? or put your motherboard model we will help you from where to download the drivers for the same??
Oct 22, 2010 | Intel Motherboard
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Wha t is a pci
Conventional PCI (part of the PCI Local Bus standard and often shortened to PCI) is a computer bus for attaching hardware devices in a computer. These devices can take either the form of an integrated circuit fitted onto the motherboard itself, called a planar device in the PCI specification, or an expansion card that fits into a slot. The name PCI is an initialism formed from Peripheral Component Interconnect. The PCI Local Bus is common in modern PCs, where it has displaced ISA and VESA Local Bus as the standard expansion bus, and it also appears in many other computer types. Despite the availability of faster interfaces such as PCI-X and PCI Express, conventional PCI remains a very common interface.
The PCI specification covers the physical size of the bus (including wire spacing), electrical characteristics, bus timing, and protocols. The specification can be purchased from the PCI Special Interest Group (PCI-SIG).
Typical PCI cards used in PCs include: network cards, sound cards, modems, extra ports such as USB or serial, TV tuner cards and disk controllers. Historically video cards were typically PCI devices, but growing bandwidth requirements soon outgrew the capabilities of PCI. PCI video cards remain available for supporting extra monitors and upgrading PCs that do not have any AGP or PCI Express slots.
Many devices traditionally provided on expansion cards are now commonly integrated onto the motherboard itself, meaning that modern PCs often have no cards fitted. However, PCI is still used for certain specialized cards, although many tasks traditionally performed by expansion cards may now be performed equally well by USB devices.
Jan 18, 2010 | Intel D845GVSR Motherboard
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Toshiba Satellite A105 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
