Question about Poulan Plumbing
Need utilitech 3125 1 hp shallow well jet pump manual
Utilitech 3125 1 hp shallow well jet pump manual 115/230 volt
4 Suggested Answers
  • 308 Answers
SOURCE: pool pump burned out - Wayne WIP150
You can go and buy a new motor, but that is about it...short of having the motor rewound, but I think you would find this to be a more costly option.
Posted on Jul 08, 2009
  • 89 Answers
SOURCE: 1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Posted on Jul 19, 2009
  • 832 Answers
SOURCE: Sears 1/2 hp shallow well pump wiring for 230 volts
You don't need to touch the pressure switch when you
convert it to 220. By the way, is it possible for you to send the me the brand of the electric motor driving it
so I can help you. Send you e-mail asap. Thanks and God Bless U.
Posted on Oct 27, 2009
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Once the water is shut off the pump keeps running
the pump is controlled by the storage tanks pressure switch , if it continues to run well after the pressure tank has refilled with water , either the switches manual override has been activated (lever) or its defective or blocked off with mud
Jun 27, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How do I replace the bearings ? can I get a manual on this ?
Yes you can get a parts diagram, a manual(usually downloadable version) At ultitech.com then select: parts/ manuals /schematics.
May 11, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
How to turn on
Need to know at what stage of the pump installation you are at.
Dec 18, 2013 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Nov 02, 2012 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Plumbing Logo
235 people viewed this question
Top Poulan Plumbing Experts
Donni Steen
Tom Chichester
Are you a Poulan Plumbing Expert? Answer questions, earn points and help others
