Question about Texas Instruments TI 30XIIS Scientific Calculator
I can't figure out how to multiply a number by pi on my TI-30xs multiview...I tried the obvious to no avail
I tried parenthesis around the number and the regular *...My teacher couldn't even figure it out!
3 Suggested Answers
  • 7993 Answers
SOURCE: how do i enter the formula into my calc for a
This is for the TI-30 XIIS. It should work for you once you find the (nCr) key or the menu item under PRB key. If you know the formula skip to Exemple
Let us start with a review of the formula for the binomial distribution
f(r;n,p)=n!/(r!(n-r)!)x(p^r)x(1-p)^(n-r)
But n!/(r!(n-r)!)=(nCr) you get
f(r;n,p)= (nCr)x(p^r)x(1-p)^(n-r)
Exemple : n=25, r=6, p=0.7
f(6;25,0.7)= 25 [PRB] [-->] 6 [ x ] {0.7[ ^] 6 }[ x ]{0.3[ ^ ]19}
The arrow means a horizontal scroll once to select the (nCr) function. [ x ] stands for the multiplication sign.
[ ^] is the raise to the power key
The { } are used here as parentheses to make formula legible.
Hope it helps
Posted on Oct 09, 2009
  • 457 Answers
SOURCE: how do I get H3O
The calculation is not difficult:
To solve your example on the TI-30XS, key in:
And get the result (rounded to three digits),
Posted on Mar 04, 2011
I am trying to add/subtract & multi/divide with a TI 30XS. I can't close the parenthesis. I'll enter the number, then x10n, the exponent, but when I try to close the parenthesis it display
Are you opening the parentheses in the first place? If you don't have a left parenthesis then you don't need a right parenthesis.
Could you post the exact sequence of keystrokes you're using?
Apr 04, 2013 | Office Equipment & Supplies
Tip
PIN UNBLOCK KEY ( Personal Identification Number unblock KEY) the personal is...
Lock code: 1. 5 digits, Used to prevent unauthorized access to certain functions on the phone 2. Where: Tools > Settings > Security > Phone & SIM 3. Default: The default lock code for Nokia Series 60 devices is 12345. 4. Forgotten - If you've changed this code and forgotten it - you will need to visit a Nokia authorized service center, who will be able to reset the lock code for you. PIN code 1. 4 digits, an optional 4 digit code to protect your SIM 2. where: Tools > Settings > Security > Phone & SIM 3. Forgotten -If you keep trying, you'll eventually get locked out and need to contact your network operator for a PUK code PUK code 1. 8 digits, You'll be asked for this 8 digit code if you've entered the wrong SIM code more than the allowed number of times. You'll need to contact your network operator to get this lock lifted.
on Apr 09, 2008 | Nokia E61 Smartphone
I'm having troubles with parentheses. How can I enter: 2-(-2) ?
Most likely you're having troubles with the negative sign, not the parenthesis.
Press 2 - ( 2 +/ ) =
The "+/-" key is the key just to the left of the "=" key, used to enter negative numbers.
For this problem you don't need parenthesis. You can simply press
2 - 2 +/- =
Sep 23, 2012 | Texas Instruments TI-30XA Calculator
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
Light on dash came on which says "IP Brake" After 21/2 hrs. at the mechanics they couldn't figure it out except to say it has something to do with the ABS system
All your saying, is that the shop you went to, has no reference
material or data base, to even know what to check on your truck
If you have the factory manuals from Helm.com, you could possibly
figure it out
I won't guess, it is an obd1 system,pre 1996, so it can't be all
that hard
All you can do, is start to research for a shop in your area, that
that is good at everything. I would ask around for a couple weeks,
and then build a relationship for years to come.
Sep 20, 2011 | 1995 GMC Sierra C1500
I have a TI-30XS Calculator and cannot figure out why the thing won't work when I try to divide numbers with scientific notation. The calculator appears to be adding exponents when it should be...
One solution that you might try is to put the scientific numbers in parentheses. For instance open parenthesis, type in the first scientific notation then close parenthesis, next hit the divide key and then open parenthesis and type in the 2nd number in scientific that you are dividing by and then close parenthesis. Hit enter or =. I'm not sure if this will fix your problem, but it is worth a try.
Aug 28, 2009 | Texas Instruments TI-30XA Calculator
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
Dividing by a negative exponent
(2x3^2) divided by (2x3^(-2))
just make sure to use double parenthesis around the negative exponent so that you get the right answer
Feb 08, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI 30XIIS Scientific Calculator Logo
106 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
