Question about Gateway (M520HD80G) Hard Drive
Connecting new hard drive
Bought a new hard drive for my gateway GM5478 computer but forget where it gets connected inside.
  • 2,427 Answers
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Posted on Oct 26, 2008
Nv79 gateway shuts off after it trys to boot?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | Gateway Computers & Internet
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
I recently bought a new hard drive to update the "tired out" model in my gateway model gt5674. i was told that i needed a SAS compatable motherboard to get this new hard drive installed. is there any...
Take the disk-drive back to the computer-store,
along with your computer, and exchange the new disk-drive for one that is compatible with your computer. Within 15 seconds of viewing the "inside" of your Gateway, they should be able to identify the correct model of disk-drive that will be compatible with your current motherboard.
Or, the more-expensive option: buy a PCI add-in card to add a 'SAS-compatible' interface (although I've never heard of such an interface!!!!) to your computer.
Jan 15, 2010 | Office Equipment & Supplies
Have an HP pavillion A1540n. after power up, get screen with "Hard disk failure imminent' "Backup files. replace Hard drive." I'm not able to get out of this screen unless I power down the computer. I have...
Sometimes it is easier to install a new hard disk and reinstall Windows.
Then either connect the old hard drive as a slave drive (don't forget to set the jumper on this drive as a slave). The other way is to connect the old hard drive to a USB hard drive adapter and connect it to a working computer's USB port. this computer will see it as an external hard drive (provided the hard drive is still functioning).
Either way you can download and backup your files.
Nov 02, 2009 | HP Pavilion a1540n PC Desktop
I INSTALLED A GEFORCE 9800. WHEN I USE THE SECOND CONNECTION WITH THE HDMI ADAPTER I DO NOT GET SOUND ON MY TV. GREAT PICTURE NO SOUND. HELPPP!!! THANKS GREGG
I had this issue with my HD DVR receiver and I have to play with the HDMI plug by moving it to different HDMI ports on my TV everytime :( try that
Rate me
Jun 02, 2009 | Gateway GM5478 Refurbished Intel Desktop...
New SATA hard Drive not recognized
hi! there,
try to check your i.d.e cable connection there several pin
connection sometime they are loosening,its good if you can replce new one.also the power supply cable,have a nice don,t forget to rate me thank's
Apr 06, 2009 | Computers & Internet
Cannot change operating system on Gateway GM5478?
Be sure you have a 64-bit system before installing this will not work on a 32-bit system.
Dec 05, 2008 | Computers & Internet
What hard drive can I upgrade my old 450ROG with?
Sure you can. You can get your hdd on ebay at very reasonable prices and new.
Here you have one of 80GB new at $ 60 free shipping
http://cgi.ebay.com/New-Hitachi-Laptop-Notebook-80GB-2-5-Hard-Drive-IDE_W0QQitemZ320309086044QQcmdZViewItem?hash=item320309086044&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1308&_trksid=p3286.c0.m14
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Gateway 450ROG Notebook
Motherboard issues
Dear, friend
When connecting IDE devices in your computer, there are a few rules you need to know about.
First, Master and Slave devices are different for the 80-wire cables and the 40-wire cables.
Inside your computer, you generally have two (2) IDE hard drive controller connections. They look this this 99% of the time:
[ The smaller one on the very top is a floppy drive controller connection )
Jul 01, 2008 | Computers & Internet
Gateway (M520HD80G) Hard Drive Logo
275 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
