Question about Canon Office Equipment & Supplies
I have a well used manual Canon Micro Printer 90. Light will not come on when energized.
    Guru:
  • 859 Answers
This is a user replaceable part. But, these parts are usually only available from Canon and mostly can only be found by having it serviced at an authorized Canon service center. Your best bet would be to determine the part number and do a search across Ebay and find an after market vendor who can sell you a used one pulled from other discarded fax machines. You may find the vendor via Ebay by entering your fax model number and this may lead you to a vendor who has replacement parts too.
Sorry to have to tell you this. Naturally, I may be wrong.
Regards,
Worldvet
Posted on Oct 26, 2008
My printer printer ip 90 doesn't work because i lost my CD for comfugulation with the computer ,how can i get CD driver?
All available drivers and software for your printer can be downloaded from here: http://software.canon-europe.com/
Feb 21, 2013 | Canon PIXMA iP90 InkJet Printer
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
Hi
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
Manual
You posted in the wrong place micro.
INSTALLATION GUIDE
USER GUIDE
Have fun.
Sep 11, 2008 | Canon CFX-L3500 IF Laser Printer
Battery pack for Canon ZR100 digital videocassette camcorder
For good spare canon nb-2lh battery,or cheap replacement canon nb-2lh digital camera battery,you can search and searh to find a famed relible camera camcorder batteries store with chargers on sale,shopping online convenient and cheap !
Jun 25, 2008 | Canon ZR100 Mini DV Digital Camcorder
Canon Pixma IP 90 printer and Windows Vista
Hi dreslsam,
Is it the Pixma 90, or the Pixma 90v? I believe there is a difference, but I could be wrong.
If you go to this link, and select Vista as your OS (operating system) you should be able to download the correct driver that you need for your printer. Make sure not to select the 64 bit version!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11009
Once downloaded, make sure you unpack it and keep in mind where it saved it to in your computer. Then, right-click your my computer. select properties, then on the left hand side of the window select 'device manager'
You should be able to quickly see a yellow question mark next to your printer on this list. If not, I would think it should be located under the 'Universal Serial Bus Controllers' section (USB) where you can update the driver manually.
To update a driver manually, right-click on the driver on your device manager, select update driver, and when prompted, do not search automatically for the correct driver (hence manually versus automatically). Select 'I will install the device myself' and navigate through the explorer menu to the location of your recently downloaded and unpackaged driver. It should now install and complete successfully. It may prompt you once that the device driver is not signed by Microsoft, but since we are sure of the location that we downloaded it from, this is not a concern.
Once you've done all that (Phew!) You may still need to go to your Printers & Faxes menu and set-up your printer and make it your default printing device. Piece of cake after all of that driver stuff right?
If you still have any questions or problems after that, post again and let us know! Hope that helps.
May 03, 2008 | Computers & Internet
CAnon Pixma IP 90
try waiting for about a day so the ink can flow down to the print head then try again
Oct 14, 2007 | Canon PIXMA iP90 Mobile Printer
old marine
old marine
