Question about Panasonic ET-LAM1 Projector Lamp for PT-LM1
How do i reset lamp hour of panasonic PT-L759u projector bulb
SOURCE: Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
This is a link to AVS for Panny PT-50LC (LCD) which I assume must be the same for the DLP.
With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds. The TV will be turned on and it will have a screen of status data atop an active TV channel. To get out of this mode TURN OFF your TV.
This initial "SERVICE MODE 1/3" screen shows -
LAMP OPERATION TIME
TOTAL :
CURRENT LAMP:
OSD DISPLAY :
LON COUNT :
Posted on May 12, 2008
SOURCE: panasonic PT-L759U
This also works for a Panasonic PT-LC50E LCD Projector.
Posted on May 26, 2008
00Steven
  • 6 Answers
SOURCE: set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Posted on Sep 27, 2008
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
  • 2326 Answers
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Posted on Jun 17, 2009
Reset lamp counter on F100 lamp
the timer chip for the lamp is on the housing of the lamp
you need a new timer chip
you can not reset the timer in the Menu setting
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Nov 07, 2012 | Panasonic Et-laf100 Lamp For Pt-f100...
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
RESET THE LAMP HOURS OF PT-LB60EA
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
I have the Panasonic pt -l759u multimedia projector the lamp timer has reached zero i need to know how to reset it i currently cant even get to the menu
You cannot reset the lamp timer. This is an indication that your lamp is at the end of it's life and must be replaced. Contact Panasonic for a replacement.
Feb 27, 2011 | Panasonic PT L759U Multimedia Projector
My pt-ax200u runs for about 15 mins then turns off. The replace bulb light is on but otherwise vents are cleaned and and cooling fan is running.
hi,
try one thing reset ur projectors lamp hour and the try
follow the procedure for lamp reset
1. power on the projector
2. press the menue button
select options and then press enter
select lamp rutime
press and hold enter buttonfor 3 seconds
confirmation screen will display and select ok
press power buttonfor turn offfor resetting the duration of the LAMP RUNTIME
confirm theduration of time in lamp run time
Jan 06, 2011 | Panasonic PT-AX200U Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic PT-60LCX64. What would happen if you
you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic ET-LAM1 Projector Lamp for PT-LM1 Logo
46 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
