Question about Pyle PLAD413 Car Audio Amplifier
Car audio amp in protection mode
I have a Pyle Audio 1,000 watt amp running 4 channels. I have a 12'' sub hooked up to it and it goes into protection mode. I troubleshooted it by removing all the wires and starting from the beginning. i found out when i plug the RCAs in, the sub goes pop and then goes into protection mode. Any ideas on how to fix?
  • 631 Answers
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Posted on Oct 26, 2008
  • marques
    marques Apr 21, 2014
    yes it goes I protect wit rcas plugged in n no the speaker dont go pop
I have a lanzar vector VCT-2210 2000 watt amp hooked up to two menace 1300 watt subs. when i turn the volume up on the head unit the amp goes into protection mode. i checked all my wiring and it seems all...
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Apr 09, 2014 | Lanzar VCT2210 Vector Series 2 Channel...
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
My amp and subs work but the subs dont sound very loud. how do i adjust my Pyle PLA4340 amp and fix this problem
Hello polarisracin,
You need to bridge 2 of the amp channels to each 4 ohm sub to get the most power from the amp. Bridge channels 1/2 to one of the subs and channels 3/4 to the other one. But the amp is only rated for 75 watts RMS per channel and Pyle products are sometimes rated higher than their real capabilities. So, even bridged and with the rated output, you'll only be getting at most 150 watts from a pair of bridged channels. That's not much for a sub.
Hope this helps.
Oct 01, 2009 | Pyle PLA4340 Car Audio Amplifier
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
LA-1030 Protect Mode
you have an unloaded channel,so the voltage is exceeding what the protect circuit is supposed to see.you have to connect an 8 ohm resistor across the output of the unused channel.
do not drive a signal into it or you will smoke the resistor.
a 10 watt will do ok with zero signal input
May 23, 2009 | Legacy Audio LA1030 Car Audio Amplifier
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Pyle PLAD413 Car Audio Amplifier Logo
449 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
