Question about Raymarine Linear Feedback Unit For Outboard Engines, 12"
1988 90 hp mercury 2stroke dies at 3500 rpm, idles smooth
Engine dies when when apply gas to it
Check for vacume leak including intake. Spray some carb cleaner around intake and vacume hoses and listen for engine rpm to change.
Aug 24, 2017 | Honda Cars & Trucks
Motorcycle Trouble Shooting
possible plug cables arcking out.
Apr 07, 2013 | Motorcycles
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
1987 mercury topaz that has a rough idle and then stalls, the car will not stay on
Three things come to mind.
First is it a rough idle at normal rpm level which could indicate the throttle body needs cleaning.
Second is you have a faulty Idle Air Control valve (IAC)'
Third is you have clogged or dripping injectors. Injectors should have a smooth cylindrical spray pattern.
Jul 14, 2009 | 1987 Mercury Topaz 2 Door
97 srad no power under 4000 rpm in, in first gear acceleration
If you have installed the Dynojet kit's carburetor needles take them off and use the stock ones.
Dynojet's needles are for track use only and the don't work properly under 4000rpm.
Jun 15, 2009 | 1999 Suzuki GSX-R 600
Car dies when in drive
dear friend should your vehicle idle below 1000 RPM it is possible for your vehicle to cut as the idle drops to low,find the compensating valve and your problem is solved.
Jan 05, 2009 | 1995 Mercury Tracer
Raymarine Linear Feedback Unit For Outboard Engines, 12" Logo
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
