Question about Nokia 5200 Cellular Phone
How to format phone memory
Is anybody knows how to format the phone memory/internal memory of a n5200? because my phone got stuck up...
  • ankuordeepan Oct 30, 2008
    how to format phone memory problem
  • Anonymous Nov 14, 2008
    memory card option not show in nokia 5200
  • Nokia Master
  • 1,800 Answers
*#7370#
default code is 12345
plz do rate this post as good as u can
Posted on Oct 26, 2008
How to format g x 500
what do u want to format??? memory card or internal flash memory?????
to format memory card, go to file manager and go to it's setting and format it. for formatting internal memory, you have to do reset factory setting in settings.
Apr 11, 2013 | LG GX500 Cell Phone
How can i formate my phone internal memory
Hi there
To format your internal memory, go to Settings>restore factory settings>restore all
Select restore all and your phone memory will be formatted
NOTE; this will erase all personal data on your phone and it will take several minutes
Oct 03, 2010 | Nokia X3 Cell Phone
Why do the videos go to internal instead of external memory?
try to do this.
1. check if your memory card is formatted using your phone formatting utility. if not, back up the files on your memory card to your computer and reinsert it to your phone and have it formatted there ( don't format your memory card from pc this is not a good idea for it).this is also a cause or one of the reasons why the files, even if you save to memory card will add to your phone internal folders. the memory card needs to adapt the phone internal first before you can use them.
to answer your question,
converting videos are not only the issues for samsung, other brands and models as well. not all video codecs are supported by 1 phone. if the manufacturers will install all the codecs for a phone player, they should install first a prom that is large enough to hold them. it's never easy huh, but look on the other side, you will learn how to convert videos not only on 1 file extensions but for many. :-)
now, to transfer files, check your phone pc connection settings, do these by selecting menu, phone settings, pc connections, and enable ask on connection, at least you can select whether you want to connect it by pc suite or by memory card. select memory card, at least on that way, you will know that your are transferring and copying files from you phone memory card to your pc and vise versa. once you had formatted your memory card, you can see the same folder as you have on your phone internals. you can easily drag and drop files.
adding videos to your internal phone, i don't believe you need to do that, but for ringing tones and alarms, the phone will immediately add them to you internal folders once you had assigned them. try going to your my files folder, and check for the files, filter them by phone and memory card. you can see the drop down list at right top hand corner of your phone and check it there if the files are there in your memory card, you don't need to copy it to phone memory. you can access the files there.
just select the files and select more for more options.
regards.
Mar 06, 2010 | Samsung Star GT-S5233 Cell Phone
My Fujifilm S5800 displays the following message..'card not initialized'. And will not allow you to do anything. Can anybody shed some light on this? thanks
My manual sugests the following for that error:
The memory card or internal memory is not formatted or the memory card was formatted in a computer or other device.
Fix: Format the memory card or internal memory using the Format option in the camera setup menu option.
The memory card requires cleaning.
Fix: Clean the memory card contacts with a soft dry cloth. If problem persists, format the memory card.
Camera malfunction.
Fix: Contact a Fuji dealer.
Hope this helps.
Feb 21, 2010 | Fuji Finepix S5800 Digital Camera
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
LG kc910 Browser cache full?
I guessed at 0000 and it allowed me to format it.
Although bizarrely it was showing that it had 1.5GB free in the memory manager thingy, but wouldn't let the camera access it
Before you format it - it might be worth checking the "Primary Storage Setting" under Memory Manager and set it to external - it might be that the internal memory is full. Indeed - it might be that the web browser only uses internal memory for it's run-time uses, so you might need to make sure that there is some free space on the internal memory, full stop. (You can always move stuff to the external drive in the media album to make space if you don't want to delete things - beware though: If you've replaced the background picture on your main screen - this must live on the internal memory).
Feb 15, 2009 | LG KC910 Renoir Cell Phone
Formatting the Nokia 6681 memory card
hello you search the card memory in you phone and you click option you shoose formate ....
or you can use it in ths pc that very simple
Jan 30, 2009 | Nokia 6681 Cellular Phone
Camera does not read SD Memory Card
thank you so much this worked great it solved my problem thanks.
Oct 31, 2008 | Kodak EasyShare M863 Digital Camera
Antivirus
Hi
N5200 me 'software download' karna na mumkin hai. 'Software upgrade' kar sakte hain. Yo vi N5200 ki hi hona chahie.
Supriyo DG
Jun 06, 2008 | Nokia 5200 Cellular Phone
How to format n73
hi there. here are some codes that you can apply with if you really want to reformat the phone memory. i am not sure if it works out with N73 but on my 7610 before it worked fine. you can just try. Be sure to back-up the your phone first.
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370# and then Yes.
Please Rate Thanks
Jan 07, 2008 | Nokia N73 Cellular Phone
Nokia 5200 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
