I have a television,the television type is sharp(A48KRD89X)and the model number is 1120304358 and when I plug in the power try to turn on but nothing comes out.theres no LED,no raster(no power).what
Model number is 1120304358
  • 8457 Answers
SOURCE: Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Posted on Sep 05, 2009
tvtek
  • 1284 Answers
SOURCE: I have a JVC Rear Projection television and there is no power!!!
If you replaced the lamp you want to make sure the lamp cover is back on correctly. If all that has taken place then you will need to have a technician look at your TV as it sounds like you have a power supply failure.
Posted on Nov 06, 2009
budmrtn
  • 11361 Answers
SOURCE: My Olevia 27in. LCD Television does not turn on
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 10, 2009
  • 8457 Answers
SOURCE: Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
Posted on May 14, 2010
Testimonial: "Thanks for your immediate reply. It could be an issue with the TV's tuner. At times, I did noticed the sound wasn't clear after turning on the TV. I had to turn the TV off, then turn it back on to get a clear sound. Now, the stand-by red light immediately clicks off when plugging into the wall socket. The television is now in a TV repair shop. "
budmrtn
  • 11361 Answers
SOURCE: My Toshiba 42RV535U LCD television
If you have no indicator in the front at all, it means that the 5vdc standby power supply is not working, it needs this voltage for the TV to start up. Please read my guide to understand more.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 14, 2010
My sharp model LC-70LE600U just powered off while watching and now it will not turn on. Please help. I've only had the tv for a couple of years.
1st thing to try is to unplug it from the outlet, wait 2 minutes and plug it back in and try it. One of the things that could cause it to power off is heat. Check to make sure that nothing is blocking the air vents such as drapes or dust (if you find dust VACUUM the air vents (rather then brushing the dust away) If you brush some of the dust will be pushed through the vents into the circuitry forever.
Oct 01, 2016 | Sharp Aquos Televison & Video
Wont turn on
seems like a power issue.
u should have the power checked out on the tv
Oct 02, 2008 | Sharp LC-32D4U 32 in. HD-Ready LCD...
My Sharp Aquos Liquid Crystal model number LC-60LE600U will not power on. I attempted to reboot the system but it still will not power on. Can this TV be salvaged without a very costly repair?
I've had this problem on one of my sharp tv's.
Have someone help you as it's hard to reach around a large tv sometimes.
Unplug the tv. Hold down the volume down and Handel down button. Now, have the person plug in the power for you. Continue holding the buttons and you'll see the screen flash or turn on.
If that doesn't work, try holding just the power button and plugging it in. If that doesn't work, try all 3 buttons.
You'll see the red light flash green or stay green and turn on. You might hear the power supply click on or hear the buzz of the inverter.
If it doesn't work after a few tries, the backlight bulb might be bad. It's probably been on too many hours, and so, the backlight will burn out. It's not worth fixing (if you can find one) so just buy s new one. That, or the inverter is shot.
Newer LEDs do not have inverters so it'll never burn out totally. However, it is possible for a single bulb to burn out, in which you'll see a dark sport or shadow effect.
Feb 01, 2016 | Sharp Aquos Televison & Video
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
1T19937748 Sharp Television stays off
Check and replace its main power regulator board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sharp Televison & Video
My sharp Aquos LC-60LE835U suddenly when off. It will not turn on, The center icon flashes one quick blink the one longer blink over and over. I have tryed the rest that sharp has outlined. It just...
If you wish to get more details about the blinking codes, check the site linked here. It is not practical to type in all details here by this window. http://electronicshelponline.blogspot.com/
Sep 18, 2013 | Sharp Televison & Video
What is the watt of cinemaborg sharp television
Hello
Just give me the exact model number of your Sharp TV. Cenemaborg is not a model number. It is a model name. Model number can be located at the back cover of your TV, either by itching of label sticker. OK.
Mar 02, 2011 | Sharp Televison & Video
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
No power
Does this model have a removable power cord? Check to make sure that the cord is inserted fully if it this type. Also, Have you tried to turn on the set using the front panel control?...accordianman
Aug 29, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
