Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer won't align cartridges - HP OfficeJet 6110 All-In-One InkJet Printer
  • 1 more comment
  • tanaparker Nov 03, 2008
    printer will not align new cartridges
  • Anonymous Nov 04, 2008
    printer will not align new cartride
  • dbrmosher Nov 23, 2008
    Iput the new ink cartridge in and hit the scan button to align and the Black ink lite keeps flashing
    Scholar:
  • 162 Answers
Align cartidges printed test page comes up after that put it on scanner and click on scann button . after that you are able to print any document.
Check and follow the link for details
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657&dlc=en
Posted on Nov 25, 2008
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
799
Posted on Feb 28, 2009
3 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: after installing two new cartridges
Welcome to Fixya
Try to print a quick seld test page. See if the printer were able to print a test page.
1. hit the "Setup" button.
2. hit the right arrow to "Print Reports"
3. hit the "ok" button
4. hit the right arrow to "Self Test"
5. hit the "ok" button
If you were able to print the test page, then there is no problem with the printer. Try to print a word document then see if you will be getting the same problem.
Thank you for using Fixya!
Posted on Jul 04, 2011
  • 601 Answers
SOURCE: printer cartridge alignment checks
Is this with new cartridges or refilled?
If refilled, the nozzles may have become blocked which isn't the easiest thing to clear. If new cartridges, take them back for a replacement at the store and try again with new ones
Posted on Dec 12, 2011
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
Printer cartridge alignment checks
Dec 12, 2011 | HP LaserJet 1320 Printer
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
Aug 08, 2011 | Lexmark X4270 All-In-One InkJet Printer
The check print cartridge light is on and won't go off even after changing both ink cartridges
This could be a number of problems. Depending on the printer and ink, you may have to power cycle it (turn it off and then back on after a minute). Many printers nowadays also have you do an alignment page. You may want to attempt to do an alignment page if your printer has that functionality built in. If that doesn't work, as silly as it sounds, check to make sure both ink cartridges are locked into place securely, even if you need to remove them and put them back in.
Aug 04, 2011 | Office Equipment & Supplies
Put in new cartridges and now won't print says need to align
Hi! your printer need to print head alignment requirement.
click> Start
click> control panel
click> printer and faxes
you can see there your printer icon right click
choose printing preferences
then click maintenance
wait for test print finish.
see attach picture.
May 31, 2011 | Canon Office Equipment & Supplies
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
HP Photosmart C4280
hmmmm...assuming that the cartridge is installed properly, yes? seems that your black ink cartridge may need to go through a 'clean' process, prior to alignment(sure wish that the replacement folks would insist on cleaning out the old heads, before doing an alignment. It's like changing the oil on your car, but using the old filter. Same gunk still in the system.
Jan 29, 2008 | HP Photosmart C4280 Aio Printer
K60xi won"t align cartridges
what are going to do is just fix thee color ink cartridge of your printer......
Jan 26, 2008 | HP OfficeJet k60xi InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
1,669 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
