Question about Whirlpool GGQ8831L Gas Dryer
Maytag permforma dryer
My dryer heats up fine. but the cylinder in doesn't spin. does that spin on a belt? and how do you get to the belt to change it?
  • 67 Answers
Yes, there is a belt. usually, you need to first take off the panel on the bottom of the front, then the main front panel (the one that has the door in it) then the panel that supports the drum, then gently slide out the drum. you might have to look on the internet for a belt routing diagram for your specific model
Posted on Oct 28, 2008
Cylinder wont spin. dryer heats up and everything seems to be working fine, but it doesnt spin. how can I fix this?
sounds like the belt drive has snapped. you can buy a new one for around £15-£20
try www.e-spares.co.uk
Dec 02, 2010 | Dryers
Drum won't spin - dryer heats up just fine
the drum drive belt is broken and needs to be replaced.
Apr 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Replaced belt & pulley, now drum won't spin properly
Belt mounted upside down. Slick side goes to tub on this odd ball machine.
Mar 08, 2009 | Maytag SDE2606 Electric Dryer
Dryer not spinning
ok this sounds simple
if the dryer stopped spining there are 4 things to look at
1 the belt for dryer if this snapped the drum will stop spining
2 the dryer wheels these ware down and break off this is what helps keep dryer in a spin straight
3 this is the crucial one the motor siezed up from lack of appliance oil not being added to a regular maintenance
4 the guages has stopped working but i doubt this if it still keeps a timer going round this would not be it you dont have to run dryer to test guages just set guage to a time and see if it rotates with the time on it
the belt you can check your self by pulling down the dryer pan that will show bottom of dryer with belt if its a belt simple maytag can come out and do a replacement and maintenance on the spot
i hope this helped seeing im not there to actually see in person whats actually wrong
May 17, 2008 | Maytag LSE7806A Top Load Stacked...
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
