Question about Sentry Fireproof Safe
How to replace solenoid on sentry safe - Sentry Fireproof Safe
3 Suggested Answers
TeaCii
  • 90 Answers
SOURCE: Sentry safe default admin code
I hope you registered you safe after you bought it. If not you still have a chance. Contact their support here.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
SOURCE: The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Sep 28, 2010
Replacement key for a sentry 1170 key #C001B
Use the Sentry Manufactures website to purchase a replacment key.
Sentry Safe Need Key
Dec 25, 2015 | Sentry Safe - 1170
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
Cannot open safe and I have changed the battery
If you removed batteries more than 1 or 2 times in a row, safe may revert back to a factory setting.
The factory number should be on your instruction sheet that came with the safe.
Contact Sentry for the factory safe number that came with your safe.
However, if the safe was not opening before you replaced the batteries it may be a faulty solenoid.
Terry Whin-Yates BA Hons (Criminology)
3rd Generation Master Locksmith
25+ Years Experience
BC Security License : B4227
604-773-5625
http://www.mrlocksmith.com/
Dec 27, 2010 | Sentry Safe Qe4531 Firesafe Waterresistant...
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
Dead battery and safe wont open
battery cover can be removed from outside. replace batteries and try again but if you remove batteries more than 1 or 2 times in a row, safe will revert back to a factory setting. That number should have been on your instruction sheet when bought. Good luck though, I bought a Sentry A3821 and it's only 5 years old and won't open.. After help from sentry I was told solenoid is bad and no longer made. So I now have a piece of junk bolted to my floor
Oct 27, 2010 | Sentry Fireproof Safe
Lost combo sentry v530
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 27, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
CAN NOT OPEN MY SAFE, MISPLACED INFO, LOCKED CODE NUMBER IN SAFE. ELECTRONIC FIRE SAFE NUMBERS ON OUTSIDE OF SAFE OA3817 BA69609
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
May 01, 2008 | Sentry Fireproof Safe
Lost key to sentry safe
You have to contact Sentry directly to get another key
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Dec 30, 2007 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,570 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
