MCS 6730 linear tracking turntable - Audio Players & Recorders
4 Suggested Answers
SOURCE: Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Posted on Sep 22, 2008
djproaudio
  • 515 Answers
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
Pulkit558
  • 472 Answers
SOURCE: how do I replace the belt on my Realistic LAB-1500
Getting Started
  1. Remove the rubber platter mat if your turntable uses one. Set it aside.
  2. Lift the platter straight up and off the center spindle to expose the turntable belt.
  3. Remove the original belt and check it for wear. Generally, a turntable belt doesn't slip unless it's damaged. If it is damaged, purchase a new one.
For a Two-Piece Platter Turntable
  1. Loop the replacement turntable belt around the cylinder located underneath the platter.
  2. Check that the belt is working properly by turning the platter clockwise two or three rotations. It should smoothly move along the motor pulley. If it doesn't, adjust it and turn it again.
  3. Replace the platter, and then carefully lay the rubber platter mat over it.
  4. Turn on the turntable and check it for correct movement. If it looks like it's working, play a record to make sure all is in order.
For a One-Piece Platter Turntable
  1. Loop the replacement belt around the cylinder located underneath the platter.
  2. Replace the platter carefully. One-piece platter turntables are delicate, and if you force the platter down or push it at an angle, you might damage the platter or spindle.
  3. Turn the platter so the hole in it lines up with the motor pulley.
  4. Pull the turntable belt and loop it over the motor pulley. Position it on the pulley groove to make sure it won't slip.
  5. Rotate the platter clockwise to make sure the belt is firmly in the pulley grove. Moving it two or three times ensures that it's in place.
  6. Put the rubber turntable mat back on the platter.
  7. Turn on the turntable. Play a record if it looks like everything is working to check the speed.
Posted on Aug 17, 2010
How do I access tone arm belt and motor on a Pioneer PL-L30 turntable?
Try lifting up the turntable mat. You should see a hole. Note how it fits before removing the belt.
Oct 10, 2014 | Audio Players & Recorders
I have a jvc l-600 fully automatic turntable tracking linear.where can i get cables in anchorage?
You should be more specific, but I will assume you mean coax cables with RCA plugs to connect your TT to your amp.
Walmart or Radio Shack should stock cables that will work.
Search Mouser.com, Digikey.com or Parts Express for bettet quality cables.
May 02, 2014 | JVC Audio Players & Recorders
Linear Tracking Turntable adjustments
I have the service manual for the LT-120 which explains how to do that. There are explanations with diagrams, etc. that won't help without your being able to see them.
Feb 13, 2012 | Audio Players & Recorders
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
May 17, 2010 | Audio Players & Recorders
Suggested lubricant for Technic SL-5 linear tracking tonearm
technics used special grease for lots of their products, any good quality grease will do but use sparingly
Apr 07, 2009 | Audio Players & Recorders
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Problem with technics SL-L20 linear tracking turntable
Not sure what your question is? Linear tracking turntables also have an assortment of gears and pulleys which make it function correctly. Sometimes the drive belt will break, other times, the gears will crack. You will have to open her up, and take a look inside to see if there are any components which are damaged. There may also be grease applied to the gears, which might also be preventing it from moving properly.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 22, 2008 | Panasonic Audio Players & Recorders
207 people viewed this question
 Grubhead
Grubhead
