Question about AOpen AX4SPE-UN Motherboard
Universal case front panel where do i connect wires on motherboard
2 Suggested Answers
mastericpr08
  • 571 Answers
SOURCE: say me the wire color
Use this photo or download the manual from here
http://safemanuals.com/user-guide-instructions-owner-manual/AOPEN/AK77400N-_E
Posted on Jan 09, 2011
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with IntelĀ® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Nov 12, 2010 | Computers & Internet
Have no manual for icute A78BN ATX case, how to connect the right cables to the ECS motherboard.
just plug the 20 or 24 pin from the PSU to the motherboard. it's the only one, you'll never missed it
Mar 02, 2010 | Computers & Internet
Get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
Feb 12, 2010 | Intel D875PBZ Motherboard
I recently installed a motherboard to a universal computer case and i am trying to connect the front panel connections to the motherboard withoiut shorting the board. can you please share with me the...
There should be a color sticker with your motherboard. only with that, thos can be done. because, this is not same for all motherboards.
rate me if it helped you.
Apr 04, 2009 | Foxconn Computers & Internet
Connect wires to the motherboard
Please tell me the model number then I will be able to help you.
Nov 14, 2008 | E-Machines eMachines Desktop PC
How to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
look in manual for the computer case ..will identify which cables are for which front panel source..then in manual (online or paper) you route to your motherboard for USB/sound etc.... good luck
Nov 10, 2008 | Intel Motherboard
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
Front pannel connection on the mother board d815eea2 motherboard
Hi Billy, please use the manual to help guide you. Turn to page 33. If you no longer have the user manual please download it from this link: http://download.intel.com/support/motherboards/desktop/d865gvhz/sb/c70845001.pdf
You will need adobe reader to view the manual. You can down load adobe for free at this link:
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Or directly from Adobe. http://www.adobe.com/products/acrobat/readstep2.html
On pg. 3 is a picture of the motherboard's front panel pin connections. Item "C". (Front Panel pin to case LED's).
Armed with this information (Pictures), you can plainly see the pin numbers.
Page 4 shows you which is positive + & which is negative - pins.
Do not be fooled by the manual name. Intel often groups like motherboards into one manual. This manual does cover Intel's D865GV & D865GVHV motherboard. The second toughest thing to do is find which case wires or positive & which are negative.
This changes from case to case. Look at all your front panel wires. Most common ground is white in color. Positive wires are colored except internal case's speaker 2 wire. Black is negative.
Good luck Billy!
Hope you find this helpful.
Mike
Aug 08, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
AOpen AX4SPE-UN Motherboard Logo
264 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
