Question about Whirlpool Washing Machines
Awz 5120 e manual
857595115000 - AWZ 5120 E - Washer dryer
SOURCE: where to find quick guide of whirlpool AWZ 475
I have moved into an apartment with a whirlpool AWZ475 washing machine with no instructions. Is there somewhere I can get an operators instructions on line ?
Posted on Aug 05, 2009
  • 66 Answers
SOURCE: whirlpool awz 475 washer/dryer combo, clothes will
make sure filter is clean, and that exhuast hose is not kinked , not allowing flow, , also door switch may be bad, or timer is defective
Posted on May 19, 2010
  • 8 Answers
SOURCE: start light blinking on awz 475 whirlpool washer/dryer
Wash the washer with olive oil.
Posted on Jul 29, 2010
  • 6277 Answers
SOURCE: Have a Whirlpool AWZ 412
It could just be that there is water still left in the washer because the drain pump/motor has been unable to remove it.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 05, 2011
  • 6277 Answers
SOURCE: I need a user manual for a whirlpool AWZ 412
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from a
ll over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
John C.
Posted on Oct 05, 2011
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
Where can i get a manual for whirlpool awz 220
Hi, you can find the AWZ 220 manual at NoDevice.com, e-ServiceManuals.com, or Manuals-In-PDF.com. (You'll probably have to pay a small fee to download it.)
Sep 20, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirlpool AWZ412 No Instruction Manual - Dryer
https://www.2instructions.com/search.php?cmarque=WHIRLPOOL&modele=AWZ%20412-1250
Sir, go there and fill the related blanks and order online. EX:- Fill the description with " Front Load Washer " and E-mail section with your E-mail address. Thank you.
Sep 18, 2009 | Whirlpool AWZ412 Front Load Washer
Where to find quick guide of whirlpool AWZ 475
Mar 04, 2009 | Whirlpool Washing Machines
Washing Machines Logo
295 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
