Maytag MAH7550AAW problem
Our washer does not seem to pump out all the water once it's finished spinning and also has a musty smell...I've removed the pump and there are no blockages...water can be heard sloshing round when you rotate the drum by hand...but you can't actually see any water on the bottom of the drum...can you give us any ideas please?
  • jonomi Oct 26, 2008
    What's the easiest way to remove the drum from a MAH7550AAW...can it come out thru the front door?
  • 1,800 Answers
Hi
click on the links that will help u to knw the part
plz do rate this post as good as u can
Posted on Oct 26, 2008
    President:
  • 2,712 Answers
From repairclinic.com:
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
You may also want to check the drain line for a possible clogging..
  • Swilin Sampson
    Swilin Sampson Oct 26, 2008
    Depending on your model, you will either have to take it out from the back or the bottom.
  • 899 Answers
You will need to take the tub out then inside the other tub there will be a filter screen before it drains out of the tank , that is probably clogged and needs to be cleaned , also you might want to check the hose that comes from the tank and goes to the pump
  • jason Oct 26, 2008
    take the hose off the bottom of tub and see if it has stuff blocking the drain
    if not then the motor could be getting weak
    electech
I have a whirlpool cabrio washing machine. I have a problem. Our clothes are coming out smelling musty and nasty. They dont start smelling until they are wet, like with sweat Or the towels when we dry off...
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
Sep 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
When you spin the drum around it makes a sloshing sound
Your unit is not draining correctly. The mold and musty smell you notice is a result of that water becomning stagnant that that is not being pumped out.
The repair manual 16010061.pdf states to check the drain for restrictions. After that if there are no restrictions you check the pump motor for 18 Ohms across the winding terminals. The final step is to change the pump.
Here are the steps for cleaning the pump:
CLEANING THE PUMP
The pump assembly can also be disassembled without removing the hoses from the pump
(See Figure 6-6). Not included in post
1. Depress the locking tab on the face of the pump housing. Top Rh front of rectangular box on pump body side.
2. Rotate the block portion of the pump containing the motor windings toward the front of the washer. This will disengage the locking tabs of the pump housing from the pump face.
3. Carefully remove the pump body away from the housing. The drain impeller is exposed for cleaning.
Thanks for using FixYa.
Kelly
Jun 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
There seems to be water left in the machine. When
Water gets inside the top plastic ring on some machines. You would need to remove the inner tub to get at it to empty the darned thing!
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Jul 29, 2009 | Maytag MFC2061HES Stainless Steel French...
Water seems to be left in bottom of washer
This is a Maytagism for this style of washer.
Quick solution... take a terry towel and wipe out the standing water in the front door seal area and when you're done, toss the towel into the wash load.
Also make the loads a little smaller...it will keep the smell from reoccuring as much.
Jun 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
