Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Number 8 flashes on display screen and disk changer is stuck
I have a new One More Time 100 Cd jukebox. I tried to program it to play with only 6 CD´s. It did not work and the machine could only be prompted to play manually. Now it is stuck placing and removing a disk over and over again while the number "8" flases on the display screen. Turning the machine on and off doesn´t seem to work as as soon as the power is on the disk changer continues its repetitive action. Please help!
  • Anonymous Dec 17, 2007
    Yes, I have the same problem and cannot find someone who repairs in this area. Can someone please help?????
  • prasadrs27 Feb 06, 2009
    I have the same problem. If you are dallas based repair person please give me the contact info ASAP. Thanks.
    Prasad
The white plastic actuator is broken, if you look at the gearbox towards the back you can see a white micrswitch actuator attached to the rod the goes from the gearbox towards the gripper arm, it has a set screw on the top, it is probably loose because the plastic broke and is free from the rod goinf through the center, this is a common failure. I repair in the Dallas Ft Worth area of Texas.
Posted on Aug 25, 2008
    Problem Solver:
  • 8 Answers
The #8 indicates either the settings for the amplifier is too high so tryi turning down both channels and/or the fuse Si3 on the amplifier panel inside the wurlitzer is blown
Posted on Dec 24, 2007
SOURCE:
Only plays one song at a time; not through entire cd
This is not a problem, the machine is supposed to play only one song at a time.....If you want to play the entire CD at a time, you must first program the machine for "Album Play" and then select the disc number followed by "00". Refer to your manual for instructions on programming album play. PS I sell manuals, tech@wurlitzer-ohio.com.
Feb 05, 2011 | Wurlitzer Jukebox 1015 One More Time...
On my one more tme i can play only play 22 cd;s of ioo how do i program it /?
The number of CDs it plays is programmable to stop folk selecting fresh air if the carousel isn't full with 100 CDs. So yes you need to do that. Unfortunately I don't have the info here.
Dec 12, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a number 8 flahing on the panel,cannott play any cds just a number 8 flashing.
There are several different things which can cause this sympton. If you email me, I'll email back my phone number. I stock all parts and can repair any of the electronic units inside your machine. Please email tech@wurlitzer-ohio.com
Sep 25, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Problem
If you are near Sheffield U.K. try The Jukebox Doctor (me) who services Wurlitzers.
May 13, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Problem
A flashing 8 indicates that the gripper arm is not returning to the idle position. It could in fact be returning, but a switch is not operating properly. Feel free to email me for further troubleshooting help. tech@wurlitzer-ohio.com.
Mar 23, 2010 | Wurlitzer Jukebox 1015 One More Time...
Flashing 8 on display
A flashing 8 on the display indicates that the Selection and Credit Computer hasn't detected the gripper arm has returned to it's normal rest position over the CD carrier (where the CDs are stored). It can be caused by several factors:
1. Gripper motor switch has been turned off
2. K7 microswitch or actuator is defective
3. Blown fuse in amplifier
4. Defective gripper motor
5. Open latch solenoid coil
6. Defective Selection and Credit Computer
I am the authorized Wurlitzer Jukebox repair center for the US and would be happy to help you over the phone. I can supply parts and repair defective amplifiers and computers, etc. Please email me tech@wurlitzer-ohio.com.
Jan 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at deeddawg@bellsouth.net , I will E-mail you the 100 page manual in PDF format.
Gary.
Jun 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
My 1015 Will not accept new entries
Is it in credit? Neither will work if it is not set to freeplay.
Jul 15, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer one more time vinyl
How iwll it not play? Does the carousel rotate? Is there no sound? Does the red light flash? etc.
Jun 24, 2008 | Wurlitzer Jukebox 1015 One More Time...
1015 Display Flashing #8!
Sounds like you may have a "timing" problem with the changer mechinism. Could be a worn gear or some broken teeth on some gear or some slack in the mesh between gears and it jumped a few teeth. That would explain the doubling up and out of sequence problem with the rack and it might be the problem with it not playing too.
Jun 26, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
306 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
Mike Duncan
Mike Duncan
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
