Question about Whirlpool Microwave Ovens
Whirlpool microwave stirrer blade cover is arcing and smoking
Stirrer blade cover is arcing
BT COOL
  • 13 Answers
SOURCE: need stirrer cover for microwave
THAT MUST BE A GOOD MICROWAVE. I'M SO SORRY I COULD HAVE GIVEN YOU MY MICROWAVE.I JUST TRASH MINE IT WAS A WHIRLPOOL TOO BUT IT WAS A 2002 WELL TRY HHGREG GOOD LUCK!!!!!!!!!!!!!!
Posted on Jul 14, 2007
cactus bob
  • 267 Answers
SOURCE: Cause of burnt magnetron
GE microwaves have poor magntrons . with that said . something was wrong with the replacement stirrer . the first spark did damage to the magntron ......too bad you dont have the orig stirrer to put back in just to see what happens ..... i think your stuck,we can think anything we want but we cant prove anything and it would cost more trhan a microwave to fight it in court ...... get a new one , but not a GE
Posted on Jan 23, 2009
FitzOriginal
  • 842 Answers
SOURCE: Microwave is arcing on the antenna blade.
Arcing is often the result of the cover over the magnatron (The thing that produces the microwaves) being aged, burned or damaged. If you look inside the oven, you will see a cover (usually square or round and around 3-5 inches across depending on the machine)made from a flakey silver plastic/fibre material. If this is burned or has a hole, it needs replacing and this will probably cure your problem.
Posted on Mar 13, 2009
  • 5603 Answers
SOURCE: My built in AEG electrolux microwave has started
The plate should be an insulator and NOT causing the arcing.
Arcing is caused by EITHER not having enough food load with moisture content, OR using containers that have METAL in them INCLUDING bowls with metallic decorations or silvery/gold painting.
Posted on Sep 09, 2009
  • 430 Answers
SOURCE: What is a stirrer cover
That burning part is referred to as the stirrer cove, unless you have one similar on the bottom.It's like plastic pie plate. The fan stirs the microwaves and heat in simple terms.
Unless food is burning off it , I would be replacing the unit or have a qualified, trained microwave tech service it. You need a microwave leak detector to work on them safely. Given the cost most are disposable these days. Be Safe on this one
Posted on Sep 13, 2009
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Apr 04, 2013 | Samsung CE1031B Microwave Oven
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
Getting sparks when in use Whirlpool GT4185SKB. This was made in 2003. What is the problem? If not possible to repair, is it still available new? Thanks.
If your microwave has a turntable its probably just burnt food inside or above the oven chamber that has carbonized. If it doesn't have a turntable its possible the stirrer above the oven chamber is stuck and not moving the microwaves around, therefore causing over heating and arcing. It also could be that the stirrer blades are hitting inside. Hope this helps
Feb 21, 2010 | Whirlpool GT4185SK Microwave Oven
I getting sparks from top inside unit while cooking Could this be stir motor
Hard to say for sure without a model number but if it has a stirrer on top than the stirrer is not turning and the microwaves are arcing off the blade.
Eric
Sep 18, 2009 | Microwave Ovens
The microwave starts, then stops after a few seconds, and smells
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Sep 07, 2009 | Panasonic NN-H504WF Microwave Oven
Jan 23, 2009 | Microwave Ovens
Neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Dec 13, 2008 | Neff H7871 Convection/Microwave Oven
My mother's GE microwave oven has a large burn mark on the ceiling of the unit. She noticed some plastic parts on the floor of the unit. She bought the combination microwave-stove about four years ago and...
That would be the stirrer assembly. It consists of the stirrer motor, stirrer blade, and stirrer cover.
Without the stirrer in place, the oven will not cook evenly and may arc and spark.
Without the cover in place, food particles and grease can get on the waveguide and magnetron, and cause arcing damage.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you need to replace the stirrer motor, you'll probably have to pull the oven from the wall. You can download GE owner's manuals and installation instructions here.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Dec 02, 2008 | Microwave Ovens
Microwave Ovens Logo
238 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
